Oil Guage PSI High After Oil Change
Old Dec 14, 2013 | 06:37 PM
musty's Avatar
musty
Default Oil Guage PSI High After Oil Change
Hi all,
About 2 nights ago my oil gauge was high, almost to 120. Then a day later it exceeded it. I got a new oil change this morning with amsoil and it still is past 120. I drove for about 15 miles on it after the change. This has never happened. Is there an issue? I recall the mechanics saying I was low on oil with the dip stick. They added about 5-6 bottles of oil. Is there something wrong with the engine, such as oil burning fast? Am I able to live with this and continue my every 5k oil change? If I want peace of mind how should I fix this gauge problem? Thanks a lot.
Old Dec 14, 2013 | 10:15 PM
Zim_Returns's Avatar
Zim_Returns
http://www.z1motorsports.com/350_g35...oducts_id=4468
Old Dec 15, 2013 | 09:18 PM
musty's Avatar
musty
my car is 05'. is it fine if i don't replace this? and do i need to replace only one?
Old Dec 15, 2013 | 09:22 PM
midz350's Avatar
midz350
The OEM oil press gauge is not accurate. I think Nissan put it there just for decoration.
Old Dec 16, 2013 | 12:46 AM
GilLeonard's Avatar
GilLeonard
Default Re:Oil Guage PSI High After Oil Change
Hay guys if you have any problem related to oil change plz contact with Gil's Automotive Services. They can answer all questions related to oil change. also they provides expert services that will makes your car running smooth as ever.Gil's Automotive Services center offer a wide range of auto repair services including Tires change , Brake Service, Import Car Repair , and Towing service
Old Dec 17, 2013 | 06:12 AM
musty's Avatar
musty
bump, still need some help with this. trying to fix this problem this coming weekend. thanks
Old Dec 17, 2013 | 09:55 AM
POS VETT's Avatar
POS VETT
What weight oil? When it reads very high, what is engine speed and what is temperature outside? Is the high reading only when the engine is relatively cold?
Old Dec 17, 2013 | 10:04 AM
Syner's Avatar
Syner
Good job. Are you a vendor? No? Don't advertise, goober.
Old Dec 17, 2013 | 12:55 PM
midz350's Avatar
midz350
^ I reported his post like two-three days ago!!! still not banned!!!
Old Dec 17, 2013 | 06:48 PM
bealljk's Avatar
bealljk
oil pressure sending unit…this topic has been covered at least 3 times thus far…try searching…
swap the oil pressure sending unit during your next oil change...
Old Dec 17, 2013 | 07:46 PM
dcains's Avatar
dcains
Hay guys if you have any problem related to oil change plz contact with XXXXXXX They can answer all questions related to oil change. also they provides expert services that will makes your car running smooth as ever. XXXXXXXX center offer a wide range of auto repair services including Tires change , Brake Service, Import Car Repair , and Towing service
What is this bullsh!t? Post reported 'tard.
Old Dec 19, 2013 | 06:33 AM
musty's Avatar
musty
where can this unit be purchased? and what is the price range?
Old Dec 24, 2013 | 05:42 PM
musty's Avatar
musty
happy holidays bump. help please
Old Dec 25, 2013 | 05:29 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
What in the fck is up with this da thread. Um maybe give us info. Why would they add 5-6bottles of oil? That sounds like it's overfilled. Why were you low on oil? How long was the previous oil change interval? This is info people need to help. How many miles? What mods? How did they measure your oil that they drained out?
Help guys my dick is huge. What should I do?
Old Jan 6, 2014 | 02:00 PM
musty's Avatar
musty
oil gauge just doesn't work anymore. oil is fine, not over burning. what can i do if i want to fix this. is the oil gauge really even needed?
Old Jan 6, 2014 | 05:15 PM
flynzed's Avatar
flynzed
Oil pressure sending unit, check out rockauto.com. This is a common problem as mentioned previously. The sending unit cost about $50.00, take care not to over tighten or cross thread.
Old Jan 29, 2014 | 09:47 AM
musty's Avatar
musty
do i need to correct this gauge reading issue? other cards don't seem to need it...
Old Jan 29, 2014 | 01:25 PM
myfirstzcar's Avatar
myfirstzcar
Damn I better get down to Gil's, I'm sure it's right around the corner
Old Jan 30, 2014 | 12:07 PM
flynzed's Avatar
flynzed
You can ignore it if you choose, however, if something were to go wrong with you oil pump, how would you know?. This is a $65.00 fix and yes, many of us have had to deal / correct this problem.
Old Feb 5, 2014 | 03:23 PM
marcster13's Avatar
marcster13
LMAO at post #18
apex locator
Jul 23, 2021 02:27 AM
