Engine knocking/squeal
Old Dec 21, 2013 | 06:10 PM
350zadam's Avatar
350zadam
Default Engine knocking/squeal
Did a donut today, lasted about 15ish seconds. As I'm driving away, the car dies. I go to start back up, and it's making a horrible knock/squeal noise, and low oil pressure light is on. I pull over to parking lot, let it sit for 10 mins, and start again, sound is still there.
I then pushed it by hand into a parking spot, and while pushing it, it makes a squealing sound, as if the ebrake was on but it's not.
I am going to have it taken to mechanic Monday, but I cannot understand what could have happened. It was nothing the car Should not have been able to do/ hasn't done before. 5-6.5k Rpms it reached at most, so I can't understand how it would have broken anything internally in the engine. Checked the oil, and it's fine. Oil and coolant was plenty warmed up, had been running for 1+ hour.
06 mt 193k miles 53k on new engine replaced 3k miles ago.
Old Dec 21, 2013 | 07:23 PM
dcains's Avatar
dcains
Check p. 53 of the owner's manual. It specifically says not to do donuts.
Old Dec 21, 2013 | 07:33 PM
djamps's Avatar
djamps
when the oil light comes on it's one of two things -- bad sensor, or zero oil moving thru the engine. Given the other issues (engine making noises / not running) I'd say the engine is toast...
Old Dec 21, 2013 | 09:08 PM
ProChargedZR's Avatar
ProChargedZR
I would be willing to bet that your donuts kept your oil pickup from doing its job and the engine failure is from oil starvation.
Old Dec 21, 2013 | 09:19 PM
dcains's Avatar
dcains
We have a winner.
Old Dec 22, 2013 | 06:48 AM
oldschool350z's Avatar
oldschool350z
If it works before and then does this right after you messed it up
Oil starvation is my prognosis
Old Dec 22, 2013 | 07:01 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Always hard to make a diagnosis from afar. The VQ35DE has a deep enough sump that doing donuts should not slam the oil level over so far to create oil starvation. But since we know nothing about the replacement motor's condition or installation, it's another variable to consider. But one thing is for sure: knocking in one of these jewel-like motors is a sure sign of serious trouble.
Wonder if OP will update the thread on what the physical inspection shows?
Old Dec 22, 2013 | 08:22 AM
350zadam's Avatar
350zadam
Did a little research and from my point if view, sounds like a spun bearing. Oil level as checked now is about 1/3 of way up dipstick (as in between low and high), which definitely isn't full, but is definitely high enough to where engine should be able to operate at high speeds. Oil was changed only 1.5-2 months ago.
If its a spun bearing it sounds like the engine is toast unless it didn't gouge up the crank, which with my luck it probably did. Gonna have to drain oil and take off oil pan and check for metal shavings, whenever I have the time.
Also one more thing I forgot to add, the oil light is not on when I start vehicle, only was on briefly (4-5 seconds) until I pulled into parking lot and turned her off.
Old Dec 22, 2013 | 12:19 PM
Spike100's Avatar
Spike100
15 seconds (one thousand one, one thousand two …) is a long time to spin a car. Not even Sebastian Vettel does it that long during his “victory dance.”
I suspect your Z died (lost all power) because the electronics were messed up while doing the spins. As dcains mentions, your owner’s manual explains this.
If the squealing noise happened when pushing the car…
Originally Posted by 350zadam
… I then pushed it by hand into a parking spot, and while pushing it, it makes a squealing sound, as if the ebrake was on but it's not. ...
… I wonder if it has anything to do with the engine. Maybe not.
I’ve never had my oil light go on, but a couple of years ago I noticed a tapping noise from the engine. The dipstick showed the oil as low, but not below the minimum mark. I added oil and the tapping noise went away. The engine has been fine since, but I really watch oil level after that incident.
I hope that you do not have a serious problem.
--Spike
Old Dec 22, 2013 | 12:24 PM
dcains's Avatar
dcains
I was joking about the owner's manual, and common sense should have prevailed to protect this poor, abused Z from its F&F wannabe owner.
Old Dec 22, 2013 | 12:34 PM
Spike100's Avatar
Spike100
^^ The owner’s manual explains problems you experience with excessive wheel spin.
--Spike
Old Dec 22, 2013 | 12:36 PM
dcains's Avatar
dcains
Tells you what the oil light means, too. That's the page which is important here, since it's too late for anything else to apply.
Old Dec 22, 2013 | 12:43 PM
Spike100's Avatar
Spike100
^^ Agreed. I was surprised when 350zadam said the oil light went on when Adam also states that his oil level was still above minimum on the dipstick. I don’t think that should happen. There is probably more going on here.
--Spike
Old Dec 23, 2013 | 02:36 PM
ProChargedZR
It doesn't matter that the oil was "high enough to where the engine should be able to operate at high speeds." When the car is making a hard turn--in this case donuts--the centrifugal force is pulling the oil to one side. If the oil pickup is no longer able to feed oil to the engine, you get oil starvation.
Old Mar 15, 2020 | 10:41 PM
1998mx5's Avatar
1998mx5
dude I literally just made an account on this site so I can call you a massive *****, it's a rwd car with decent power and the guy did donuts in it, just cause you're too big of a pansy to weld your diff or your boyfriend doesnt let you drift your car doesn't mean other people cant have fun with there vehicles.
Old Mar 16, 2020 | 06:22 AM
bealljk's Avatar
bealljk
congrats on wasting your time and bumping a 6+ year old thread for what?
there / their / they're … just saying, lol
Old Mar 17, 2020 | 12:16 AM
813_350Z's Avatar
813_350Z
Cool story, bro. How long have you and OP been together?
Old Mar 18, 2020 | 03:50 PM
travlee's Avatar
travlee
Master
Coming from a noob **** waffle
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
