Extreme power loss, rough idle. Help!
Yes, a solid 1.3v on all four O2s. Occasionally on a cold start it'll try to drop down to a normal fuel level, stutter, and then rise back up to 1.3v. And then stays there wether I'm accelerating or just cruising. Very very odd and confusing. Just threw a P1164 code today as well
That code says O2 sensors all the way, but of course it could be wiring. The steady 1.3v says it's running well beyond the range of the sensors, which is rich enough to cause all the power loss, misfiring, and rough idling.
I'd hate to say you need at least 2 new sensors, but from my computer desk that's the best I can do.....and then I have to wonder what could've caused this issue.
I have an 03 w/ no mods and had the same symptoms as you w/ the p0300 random misfire code. Turned out to be a bad coil for me. Problem started slowly and was intermittent, a year or 2 later it kept getting worse. Kicking myself that I didn't test the coils sooner (disconnect one at a time to see which one made no difference). Hope this helps.
FIXED! Here's the follow up: took it into the shop, both front oxygen sensors were reading out of spec. Replaced them, better, but it still did it. Replaced one of my other after-cat oxygen sensors FIXED. All three O2 sensors, AND my maf sensor went bad at the same time!!! Who would've guessed....just happy it's all good now
