Air Filter over or under oiled?
Old Dec 28, 2013 | 06:20 PM
x_hawker's Avatar
x_hawker
Default Air Filter over or under oiled?
Hi guys, I just washed my JWT Popcharger and am currently in the process of oiling it; but I can't determine whether it is under oiled or not. Disregarding the unevenness of the oil, does the filter look too pale to you guys?
Old Dec 28, 2013 | 06:28 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Looks good to me. At least it's consistent. Give it a few minutes to settle and then spray where needed.
Old Dec 28, 2013 | 07:34 PM
myfirstzcar's Avatar
myfirstzcar
All it needs is a light film of oil, too much will dirty up your maf.
Old Dec 28, 2013 | 07:58 PM
x_hawker's Avatar
x_hawker
I did a light film but i can't tell if it's enough because I can see some white spots. I don't want to risk getting any debris inside the cylinders due to under oiling the filter. what do you think? should i oil it a bit more?
Old Dec 28, 2013 | 08:46 PM
Waiz's Avatar
Waiz
Better to underoil it if anything
Looks fine to me
Old Dec 28, 2013 | 11:44 PM
logan09's Avatar
logan09
On any air filters I've used I always did a somewhat quick pass with it on its side then backtrack fast then turn a bit and repeat overlapping the previous pass slightly. That's just my way though to ensure even coverage and no missed spots.
Old Dec 29, 2013 | 01:55 PM
StreetRacing976's Avatar
StreetRacing976
It looks pretty good to me
Just note that too little oil is better then too much.
be sure you let it COMPLETELY dry before putting it on and driving. It'll create problems with your MAF Sensor
Old Dec 29, 2013 | 03:10 PM
tcode's Avatar
tcode
I do not oil air filters at all and having 0 problems. You're good.
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
