Noise only from front driver side.
Old Jan 12, 2014 | 08:53 AM
Tone91's Avatar
Tone91
Default Noise only from front driver side.
Hearing a roaring sound whenever I'm turning left, but only at highway speeds. 2003 so tire threading possible. Didn't feel the bumpiness, but then again never felt a threaded tire. Running 19x9.5/10.5 245/35 275/35 Stock suspension didn't roll the fenders and just had new rims put on and they didn't tell me anything was up.
Old Jan 21, 2014 | 09:08 AM
jray8's Avatar
jray8
Usually, this is a wheel bearing symptom. If the noise gets worse as you turn left, the right front bearing is bad and vice versa. I would first jack up the car and turn the wheel by hand listening for any noises. Also, if you can/want, change out rims with another z owner to see if the noise goes away.
Old Jan 21, 2014 | 09:51 AM
Syner's Avatar
Syner
Jack it up and check for play.
Obadabot
Jun 18, 2023 11:31 PM
samansharif
Sep 25, 2015 12:31 PM
