PLEASE HELP - How to Read a blinking Service Engine Soon Light Soon
Old Jan 23, 2014 | 12:23 PM
MDQBoX's Avatar
MDQBoX
Question PLEASE HELP - How to Read a blinking Service Engine Soon Light Soon
PLEASE HELP - Okay, I found out how to get to where the Service Engine Soon Light will blink whatever error code made it come on in the first place. Problem is I am having difficulty deciphering the blinking light code. I recorded the sequence on video and uploaded it to youtube. If you can decipher the code, please let me know and thank you.
The video runs for about 2 minutes. I am not sure at what point it starts repeating the code.
Old Jan 23, 2014 | 01:13 PM
myfirstzcar's Avatar
myfirstzcar
P0445
P0441
You have an evap purge issue, probably the solenoid but you need to look into that before you swap it out.
Old Jan 23, 2014 | 02:21 PM
samsniss350z's Avatar
samsniss350z
The light blinks slowly 10 times after this the code kicks in with 4 fast flashes followed by a slight gap followed by 5 fast flashes then a gap then another 5 fast flashes. This gives you the code of PO455. The service light then blinks slowly 10 times and then quickly for 4 times, then a slight gap then another 4 times fast then a slight gap then a single flash. This gives you the code PO441. The PO441 code = EVAP control system purge flow monitor. The PO455 code = EVAP canister purge control solenoid valve. I hope this makes sense to you and helps you to understand how to read the code
Old Jan 23, 2014 | 02:29 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
this isnt one of those codes that can be caused by a loose gas cap?
Old Jan 23, 2014 | 04:55 PM
myfirstzcar
A loose gas cap will give a code for an evap leak, but checking or changing the cap wouldn't hurt.
MDQBoX's Avatar
MDQBoX
Thumbs up
Originally Posted by myfirstzcar
P0445
P0441
Thanks for all the help everyone.
Old Jan 23, 2014 | 04:56 PM
MDQBoX's Avatar
MDQBoX
Thumbs up
Thank you for explaining how to read the code. You saved me the effort of asking that. Thanks.
Old Jan 23, 2014 | 04:58 PM
myfirstzcar
My bad, I have to post and run since there's a 6 week old in the house now.
Old Mar 4, 2014 | 02:45 AM
MDQBoX's Avatar
MDQBoX
UPDATE - HAPPY ENDING
I thought I would just update this thread with what I discovered. Apparently the CEL/SES light was triggered by a disconnected hose. When I was checking the AT fluid, I inadvertently disconnected the hose. After reconnecting it, the warning light disappeared!!!
Uriyo_
Sep 8, 2021 08:46 AM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
