Crank/no start on occasion
Old Jan 30, 2014 | 09:20 PM
gacook's Avatar
gacook
Default Crank/no start on occasion
Hello, new forum member here.
I've got an '03 and it's started having a weird issue that is intermittent. The engine cranks but won't fire. Initially, I thought the battery was dying, so had a friend jump me (engine fired immediately). Took the car to Autozone and had them test the battery; tested good, but needed charge, so I took it home and charged it. Issue happened a couple more times, so I decided to go ahead and replace the battery. Replaced it, and now still having the same problem. Also, when it DOES start after having this problem, the belts squeal like mad. They look good...but could it possibly be the problem?
Scratching my head trying to figure this one out...
Old Jan 31, 2014 | 03:45 PM
str8dum1's Avatar
str8dum1
could be your crank sensor going out. belt squeal has nothing to do with no start. you dont need any belts for the engine to run.
Old Feb 10, 2014 | 05:47 AM
az240z's Avatar
az240z
Had this happen to my 2003. Turned out to be the starter.
Old Feb 10, 2014 | 06:45 AM
bjr's Avatar
bjr
Is it the security system? There are several threads about this and no real solution usually. Next time it is cranking and not starting look at the red LED in front of you up on the dash by the windshield. If it is on while it is cranking you are being locked out from starting the car because the key was not read correctly by the security system. You get everything but fuel delivery - the ECU cuts out the fuel so it cannot start. If this is your problem read up on it and don't try and start your car immediately three times off the same key read cycle or you will permanently lock out that key and have to try your spare key to start it!
If this is the case, you can do some research on it maybe even get it fixed by the dealer but it will cost you $ and they may not find the root cause. It can be a pain. Hopefully it is not your problem and it could be the crank sensor like was already stated. These two items are usually the cause for crank but no start.
Old Feb 10, 2014 | 03:18 PM
Neimad's Avatar
Neimad
Alt belt slipping and alt not charging battery enough.
Old Feb 13, 2014 | 04:18 PM
Bak3rme's Avatar
Bak3rme
https://my350z.com/forum/engine-driv...nd-adjust.html
Old Feb 13, 2014 | 05:03 PM
travlee's Avatar
travlee
Master
cam shaft sensor... trust me on this one...
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
Dymsi
Sep 29, 2015 11:32 AM
