03 350z headlight
Old Feb 5, 2014 | 01:08 PM
nismoracer_206's Avatar
nismoracer_206
Default 03 350z headlight
Hey guys I have a 03 with his and when I turn the switch on the headlights want come on. If I turn the switch slow they will come on but just flicker then go back off. So would this just be the switch causing the problem and should I take the steering column out and check out the switch or should I do something Elsa first? The high beams work with no problem
Old Feb 5, 2014 | 04:04 PM
Scyattica's Avatar
Scyattica
If you put the highbeam switch into the locked position with the headlight switch turned on, will the highbeams come on?
If the highbeams come on when the headlight switch on and the highbeam switch in the locked position, it's not a switch problem as the highbeams can only work (in the locked position atleast) with the regular light switch on.
Old Feb 14, 2014 | 05:37 AM
nismoracer_206
Yes the high beam will come on in lock position when turned on.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
