help trany chatter like crazy under 1.3k rpm
Old Feb 17, 2014 | 12:29 AM
kula9275's Avatar
kula9275
Default help trany chatter like crazy under 1.3k rpm
I changed clutch.
used(like new) oem clutch with spec alumi flywheel.
tranny chatter under 1.3k rpm if I press accel hard.
anyone know why this happen?
I didn't change pilot bushing or something little parts because those didn't
come with used oem clutch
Old Feb 17, 2014 | 01:59 AM
terrasmak's Avatar
Lightweight flywheel, completely normal.
Old Feb 17, 2014 | 04:28 PM
Toneloc's Avatar
Toneloc
its crackalacking don't worry keeps the cement from solidifying lol
Old Feb 18, 2014 | 07:48 AM
HK350 Z's Avatar
HK350 Z
You will get chatter and shift points will change with the new clutch.You will have to keep the revs 1800 or better or you will get the chatter, its normal.
Old Feb 22, 2014 | 06:01 PM
Martinezjr4's Avatar
Martinezjr4
Is that normal for all clutch replacements? I just had a brand new clutch put in and getting the same thing.
Old Feb 22, 2014 | 09:56 PM
terrasmak's Avatar
It is the flywheel that causes the chatter. ( for the most part) Any Z with lightened flywheel will chatter, depending on the disk installed, some will chatter more.
Old Feb 22, 2014 | 10:30 PM
GreyZ's Avatar
GreyZ
embrace the chatter, it just lets other Zs know you have a lightweight flywheel
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
Justin100
Nov 29, 2015 03:58 PM
Depravity
Oct 1, 2015 04:49 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
