Airbag Light - Diagnostic Code
Airbag light is blinking and put it into diagnostic mode.
Error code is 1 long blink then 5 short ones.
Does anyone know this pattern indicates?
Thanks!
Thanks!
Okay, I got the code...
<Occupant classification system>
- I tried the weight bypass resistor and reset it via the key method (diagnostic mode then back to normal mode), but still blinks the same code.
I've been reading that the diagnosis sensor unit needs to reset everytime an error occurs. Is this true? Do I need to replace/clear the diagnosis sensor unit in the center console?
