What repairs has your Z needed since you've owned it?
Old Mar 27, 2014 | 04:44 AM
  #61
Golden_Armz's Avatar
Golden_Armz
Wow, seems like 2003 has the most issues since its the first production year... i have a 06 with 51k and didnt do one single repair yet
Old Mar 27, 2014 | 05:05 AM
  #62
ohmicide's Avatar
ohmicide
just read the whole thread and got the opposite impression, seems like the '03 are the ones with the least major problems, just routine maintainance for most of these
I just bought mine with 86k miles, radiador is being replaced by the dealer now then it's going straight to Nissan for a 90k mile inspection
Old Mar 27, 2014 | 05:24 AM
  #63
NOLAGG's Avatar
NOLAGG
Have 102,xxx miles on my 2003 . So far I did routine maintenance , changed valve covers, greased my axles due to the clicking noise (so worth it ) .
The only problem I have is the fact I'm throwing the p302 cylinder missfire code even though I changed the injector , plug and coil and still have it every few months but doesn't effect driving .
Lastly the noisy as ***** throw out bearing lol which I've just learned to deal with until I do a clutch .
Old Apr 4, 2014 | 09:07 AM
  #64
digitalvr6's Avatar
digitalvr6
03' Nissan 350z with 94k - This one has seen better days currently thinking about trading it in or replacing the following.
-Wiper blade motor is bad (blades still work but don't go fully back to resting position)
-AC system (Getting estimates from other shops and see if the whole thing needs replacement)
- Both control arms (I was told they were bad, sometimes here a creeking noise when rotating steering wheel)
I haven't seen anyone that had to replace there system so I'm curious as to what you guys think?
Old Apr 4, 2014 | 09:32 AM
  #65
JCat's Avatar
JCat
Do both radiator fans turn on when you activate the A/C ?
(One of mine burned out, it affected the A/C)
Old Apr 4, 2014 | 12:47 PM
  #66
digitalvr6's Avatar
digitalvr6
Not sure how do I check that. I'm sure they do though.
Old Apr 8, 2014 | 07:42 PM
  #67
solidsnake's Avatar
solidsnake
160k
changed throttle body
crank and camshaft sensors
front ball joints
oil gauge sensor
window motors
faulty brake caliper and brake line
Old Apr 8, 2014 | 08:30 PM
  #68
ohmicide's Avatar
ohmicide
what's wrong with the AC? my 03 has 86.5k miles and the AC is making a bit of noise, going to get it looked at tomorrow at my dealership since the problem started after they replaced my radiator and two of the belts
AC blows cold and had no other problems thought
Old Apr 9, 2014 | 05:03 AM
  #69
ohmicide's Avatar
ohmicide
And of course its cold this morning, mechanic couldn't hear anything and they wanted $90 just to pull off the belt and check the pulleys
Old Apr 9, 2014 | 12:54 PM
  #70
digitalvr6's Avatar
digitalvr6
It seems to be working fine, no noise just no cold air
Old Apr 14, 2014 | 03:11 AM
  #71
florotory's Avatar
florotory
I'm beginning to dispose my 350z.
2003 Brickyard.
Replaced the CPS 2013
Replaced door handle
Replaced window motor2014
Replaced oil sending unit 2014
Now will be replacing upper oil pan
Need to replace hatch shocks
Replace window tint
Old Apr 14, 2014 | 02:44 PM
  #72
myfirstzcar's Avatar
myfirstzcar
Diff bushings
Knock sensor and harness with lower intake gaskets
RR brake hose
Nav screen only works in warmer weather
Old Apr 14, 2014 | 02:57 PM
  #73
npr350z's Avatar
npr350z
The previous owner burnt out the pusi magnet behind the glove box what's that about greasing the axels?
Old Apr 14, 2014 | 03:46 PM
  #74
ohmicide's Avatar
ohmicide
mine cools perfectly fine but is making a loud metalic noise, Mopar mechanic at my dealer said the compressor and pulley need to be replaced and quoted me at $1300
Old Apr 14, 2014 | 04:50 PM
  #75
myfirstzcar
I'm sure it needs something.
I've done the axle grease, and I also lubed the clutch fork pivot ball with copper anti-seize.....my best cheap fixes to date!
Mine still needs the window grease streak issue fixed, I want to replace the sound system, and still haven't gotten to the belts. Every fluid has been done and so have the plugs.
I'm also missing one plastic cap over the left rear taillight bolts.
Oh, and I replaced my license plate screws with stainless ones
Car's been awesome overall....you know, considering it's an '03.
Old Apr 24, 2014 | 11:02 PM
  #76
3Ni5M0's Avatar
3Ni5M0
New engine at 66k miles.
Old May 1, 2014 | 07:04 PM
  #77
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Have less than 59k miles on my 03 Z.
Window motors replaced
Installed CD009 trans last summer with Z1 clutch plate and FW
That's about it. Everything else has been a mod or upgrade or whatever.
Old Dec 3, 2014 | 04:39 AM
  #78
Lug's Avatar
Lug
Car is in the shop for:
driver side window motor (second motor this year)
coil pack
Ill update main post once its back from the shop.
Old Jan 12, 2015 | 06:27 PM
  #79
Valdrin Buca's Avatar
Valdrin Buca
holy **** 5 transmissions? Where the hell did you learn to drive manual? Dont mean to disrespect but thats 99% drivers fault.
Old Jan 12, 2015 | 09:42 PM
  #80
che69velle's Avatar
che69velle
I've replaced the alternator, belts battery and an oil cooler line so far on my 06 twin turbo. Needs a clutch and thanks to oil cooler line I'm gonna replace the motor to be safe and cause I want more boost. Also need to replace driver door lock actuator, rear strut cover and the cover panel behind the driver seat.
