Sensors?? WT_?!
Old Mar 13, 2014 | 04:49 PM
Spike100's Avatar
Spike100
Default Sensors?? WT_?!
When my 350z closed on 90k miles, I stated seeing the SES light… a lot. I have replaced the following sensors:
- Crankshaft sensors (one bank, then the other)
- Camshaft sensors (one bank, then the other)
- O2 Sensor
And yesterday, the SES light appears again! What now?!
I’m taking the car in tomorrow to read the new code(s).
My question: How many more sensors are there to replace at 100k miles?
--Spike
Old Mar 14, 2014 | 03:29 AM
myfirstzcar's Avatar
myfirstzcar
There are no sensors to replace at any mileage.....I guess it wouldn't hurt to change the O2 sensors, but only if they start to get lazy.
What were the codes?
Old Mar 14, 2014 | 12:45 PM
Spike100's Avatar
Spike100
^^ They said the code indicated the O2 sensor. I have replaced this sensor before. I had them clear the code, and so far SES isn't illuminated. I'll bet though it comes back on.
--Spike
Old Mar 14, 2014 | 02:28 PM
myfirstzcar
Hmmm....Ok, you know I'm no expert, but I would study the characteristics of all 4 sensors for a while using a scan tool. O2 sensor codes almost always indicate a bad sensor, but there are other possibilities.
Which sensor did you replace? Is it one of the other O2 sensors throwing a code?
To be fair, I'll just say again that replacing the O2 sensors at 100k is a good idea, since they can arguably be called a "tune up" item.
Cam sensors, abs sensors etc are hall effect sensors, 99% of the time, they either work or they don't work.
Old Mar 14, 2014 | 02:39 PM
Spike100's Avatar
Spike100
OK... Thanks for help. I'll show your post to the technician, and I will post back here once I have this solved. --Spike
Old Mar 14, 2014 | 02:44 PM
myfirstzcar
This article puts it into plain English, I refer to this on occasion....
http://www.engine-light-help.com/oxy...sor-codes.html
Old Mar 14, 2014 | 03:17 PM
Spike100's Avatar
Spike100
^^ Very informative! Thanks for good help. --Spike
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
350Z Project X
Oct 17, 2015 05:16 PM
