Hello I have a blue smoke issue on my Z
Old Mar 27, 2014 | 04:53 PM
trisk12's Avatar
trisk12
Default Hello I have a blue smoke issue on my Z
Hi my 2003 Nissan 350z start to blow smoke on acceleration cannot be seen when running but this only happen when the engine is hot no smoke in the morning either cold start is fine I figured only when the oil is hot please help?
Old Mar 27, 2014 | 05:12 PM
KornerCarver's Avatar
KornerCarver
I'm pretty sure you are beginning to burn some oil through either the valves or the rings. You might get your car to a mechanic to perform a leak down test. I would also recommend checking your oil before driving tomorrow.
Old Mar 27, 2014 | 05:17 PM
jhc's Avatar
jhc
General & Tech Moderator
Mileage and pics help...
Old Mar 27, 2014 | 05:24 PM
Spike100's Avatar
Spike100
You're burning oil. You need to check compression. --Spike
Old Mar 27, 2014 | 05:59 PM
trisk12's Avatar
trisk12
Yes compression test was done and all cylinder is good
Old Mar 27, 2014 | 06:00 PM
trisk12's Avatar
trisk12
Will the leak down test determine if its valve or rings? Thanx
Old Mar 27, 2014 | 06:05 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Have you tried to get your Z to Vape? we have a vaping thread on here. Check it out.
trisk12's Avatar
trisk12
Hi its 83k miles on it pics will be up soon thanx
Old Mar 27, 2014 | 06:14 PM
trisk12's Avatar
trisk12
Sorry im not sure what is it ill look into it thanx
Old Mar 27, 2014 | 06:24 PM
Syner's Avatar
Syner
Like other said, you're burning oil. Check the levels before you run it again.
Old Mar 27, 2014 | 06:30 PM
Spike100's Avatar
Spike100
If your valves are bad (burnt or the shaft is warped), you will likely hear some noise (usually a ticking sound).
If you are burning oil in the cylinders, you see some blue smoke from the exhaust.
If you see a white exhaust, your head gasket is leaking and probably because coolant is leaking into the engine and is burned inside the cylinders.
--Spike
Old Mar 28, 2014 | 03:43 AM
myfirstzcar's Avatar
myfirstzcar
Does it smell like it's burning oil? Are you losing coolant? Or losing oil?
Is there a rodent nest anywhere?......JK
Old Mar 28, 2014 | 06:37 AM
Syner's Avatar
Syner
If it's blue smoke, I highly doubt he's losing coolant.
Old Mar 28, 2014 | 11:59 AM
Spike100's Avatar
Spike100
[…] Is there a rodent nest anywhere?......JK
Myfirstzcar, you’re alright.
Old Mar 28, 2014 | 12:21 PM
npr350z's Avatar
npr350z
These threads always scare me! I get a little of white smoke in the morning when it's cold. I know it's just moisture ( I've checked coolant and have done a compression test and checked my oil..well I change it but I check the dipstick every couple hundred miles) I always have a mini freak out when reading this.
Old Mar 28, 2014 | 12:25 PM
myfirstzcar
Maybe he's color blind.
First thing to do is confirm which fluid is being lost. If the coolant level doesn't change, one can be extra sure it's oil.....which also has a very distinct odor.
Old Mar 28, 2014 | 12:26 PM
Syner's Avatar
Syner
Fair enough. It doesn't hurt being extra sure.
Old Mar 28, 2014 | 12:28 PM
myfirstzcar
I'm still betting it's oil though.
Most head gasket issues involve a slight misfire.
Old Mar 28, 2014 | 12:48 PM
Spike100's Avatar
Spike100
^^ I agree with you. And, I would think that compression would be compromised if his car is burning oil, but he said his compression checks out.
What do you think he might be looking at for repairs (and cost which is probably his main concern)?
--Spike
Old Mar 28, 2014 | 02:15 PM
trisk12's Avatar
trisk12
I believe ny car burn oil I add oil between oil change how much is the cost for repair if its the rings I have problem with? Or should I consider engine swap? Idk thanx evryone
