Please Help_Identify where this bolt goes
Old Apr 6, 2014 | 10:34 AM
jch217's Avatar
jch217
Default Please Help_Identify where this bolt goes
Hi All,
I found this bolt under my 05 350z today, looked underneath the car, cannot find any holes where this could go. I couldn't find any other #11 bolts. It appears to have a custom pattern at the end to prevent unthreading and also has a captive washer. Have any of you come across this bolt or know where it goes?
Thank You
Attached Thumbnails Please Help_Identify where this bolt goes-bolt1.jpg   Please Help_Identify where this bolt goes-topside.jpg
Old Apr 6, 2014 | 11:16 AM
350zsunshinefl's Avatar
350zsunshinefl
check all suspension pieces
Old Apr 6, 2014 | 11:28 AM
winchman's Avatar
winchman
It's a self-tapping screw. The gaps in the threads at the end act like the flutes on a regular tap. You can bet it was holding something important in place, but not something critical.
Was it under the front or the rear of the car? Have any major work done on the car recently?
I'm thinking something like the sway bar mounting brackets. The self-tapping screw would go into a fairly heavy section of the unit body reinforcement under the car.
Old Apr 6, 2014 | 11:51 AM
jch217's Avatar
jch217
Hi. Can't tell what region of the car it was from as I found the bolt in the driveway a day later. No work was performed. I hope the dealer can give me some insight on possible locations. You said self tapping so there is no corresponding bolt.? I wonder if a shield or other part is obstructing the hole. Thx for your help
Old Apr 6, 2014 | 11:57 AM
npr350z's Avatar
npr350z
Winch man my z Is a lady! I'd like if you took down the pictures of her under bits!
It looks like a bolt from the heat shields ...not 100% on it though
Old Apr 6, 2014 | 12:05 PM
winchman's Avatar
winchman
You know, it might have come from higher up in the engine compartment, and fallen through to the ground.
Old Apr 6, 2014 | 02:11 PM
Grimreaper87's Avatar
Grimreaper87
What size socket fits it? Have you had any work done to your car in the past year?
Old Apr 6, 2014 | 03:03 PM
92K1500's Avatar
92K1500
Looks like a 17-19mm.
And it doesn't look like any of the bolts I've removed on my Z. I've done shocks/springs/rear diff/rear subframe/clutch.
I'm going to repeat a previously asked question. What work have you had done recently?
Old Apr 6, 2014 | 03:16 PM
350zjason350z's Avatar
350zjason350z
Know it all
How are you so sure that it's to your z ... It could be from a different car... I'd jack her up an give her a real good once over
Old Apr 6, 2014 | 05:24 PM
jch217's Avatar
jch217
Its a 19mm, 100% sure its from the Z as the only other car it could from is a 97 corolla, the bolt is in pretty good shape. I crawled under the toyota to look and all the bolts are highly corroded/rusted.
jch217's Avatar
jch217
No work other than oil changes were ever done on the car, car only has 10K on it.
Old Apr 6, 2014 | 05:30 PM
npr350z's Avatar
npr350z
you still have your plasticy in the way thingy down there?
Old Apr 6, 2014 | 05:51 PM
Grimreaper87
Undertray.
Old Apr 6, 2014 | 06:01 PM
jch217's Avatar
jch217
yes, tomorrow I will remove the undertray and look at the sway bar to see any missing bolts.
Old Apr 6, 2014 | 06:15 PM
Grimreaper87
My z is up on jacks right now waiting for brakes to arrive. I cannot find anything remotely close to that bolt. Its not part of the sway bar for sure.
Old Apr 6, 2014 | 06:17 PM
silverbullet_Z's Avatar
silverbullet_Z
It's just an extra bolt, when you work on your car you once in awhile come across one.. jk, I would start by taking off the undertray and go from there check your linkage, and suspension area first but to be totally honest I dont think it belongs on the Z. I've had my fair share of disassembly and I dont recall a bolt with that kind of style to it.
Old Apr 7, 2014 | 03:37 AM
jch217's Avatar
jch217
Ok, since many don't recognize the bolt, I was thinking where could it come from. I did help a buddy put in a hitch on his Toyota Tundra several months ago, maybe the bolt came from it.
The car hasn't been moved in several months, so it could have rolled under there and I just realized it.
I will investigate this option.
Thank You to all for helping. I was convinced it was from the Z since it was under it, but started to think of other possibilities from your comments.
Old Apr 7, 2014 | 04:49 AM
Z33Garage's Avatar
Z33Garage
Could it have fallen out of a engine bay component?
Old Apr 7, 2014 | 05:11 AM
92K1500's Avatar
92K1500
It does look like a Toyota bolt.
Spare parts, not needed.
Tell him not to pull any big loads though.
Old Apr 7, 2014 | 10:38 AM
dynamic21's Avatar
dynamic21
I would still get your Z on jacks and do an inspection on the suspension and brake assemblies. Looks like a bolt that is removed often just by looking at the wear on it.
