Part#'s for Fuel Level Sensors
Old May 14, 2014 | 08:54 AM
IridiumCore's Avatar
IridiumCore
Default Part#'s for Fuel Level Sensors
Would anyone happen to have part numbers for the fuel level sensors or an O5 Touring.
I'm going through that whole inaccurate needle thing. I can squeeze around 240-270 out of a tank but I get a little nervous so I'm thinking about cleaning the contacts; I just want a firm backup plan.
Old May 14, 2014 | 08:56 AM
travlee's Avatar
travlee
Master
i dont have time to look for it right now, but go here courtesyparts.com
Old May 15, 2014 | 09:12 PM
patrickoneal's Avatar
patrickoneal
http://www.nissanpartszone.com/Page_...mponentsNo=172
Look at the bottom of the list. It looks like the part numbers have been replaced by newer numbers. I linked to nissanpartszone because courtesy obfuscates their part numbers so you can't use them to shop around. You can however type a real part number into courtesy's site and it will find it.
Old May 16, 2014 | 07:58 AM
Calinismo350z's Avatar
Calinismo350z
just went trough the same nightmare a couple of weeks ago... I would recommend to clean the level sender unit, it worked for me; it took me less than an hour to clean both sides. Good luck.
Old May 16, 2014 | 06:00 PM
bealljk's Avatar
bealljk
IC - I've got an extra fuel pump assembly - although it has a top side broken fuel hose connection. I'm not using as I replaced it after I broke the plastic hose connection a few months back. If you're interested let me know and I can upload pics.
