Swap HID harness to NON-HID headlight
Old May 14, 2014 | 07:09 PM
solidsnake's Avatar
solidsnake
Default Swap HID harness to NON-HID headlight
Silly question but cannot find the answer. I have the HID stock headlights now. I want to swap them out due to haze and moisture within the light. Ebay non HID halogen headlights are my choice of replacements. Can I just swap everything over or is there something different between the two?
Old May 19, 2014 | 12:45 PM
solidsnake's Avatar
solidsnake
BUMP! Surely someone can give me an answer. I know it's stupid but just want to be sure before I buy if you know what I mean.
Old May 20, 2014 | 07:47 AM
Koolsilver's Avatar
Koolsilver
Do you have 03-05 headlights or 06+?
Old May 20, 2014 | 08:32 AM
92K1500's Avatar
92K1500
Why would you want to go with non hid crappy ebay replacements?
If the lens is just faded get some meguiars headlight restorer.
Old May 21, 2014 | 12:17 PM
solidsnake's Avatar
solidsnake
The inside of the lense is the bad part. I would have to replace the entire lense. Basically had a bad leak on them and all the water dried up and made the inside lense cloudy so it's not something that can be fixed.
I have the 04 style lights. All I want is to swap everything over from what's on there now to the replacements just want to make sure it's a direct swap.
Old May 21, 2014 | 01:05 PM
92K1500's Avatar
92K1500
I Believe the halogen 03-05 housings used a 6 pin connector while the HID housings use a 8 pin which is the same from 03-09.
I would suggest getting 06+ housings. Look better, perform better and will be a direct swap.
You could also pull the housing open and polish the inside of the lens but that is a lot of work to still have 03-05 heads.
I have my factory housings in my attic if you want direct swap HID housings.
Old May 21, 2014 | 01:23 PM
solidsnake's Avatar
solidsnake
I would much rather just swap out the housing since that is the only part damaged. It's not a lot of work with throwing in the oven then resealing. PM me
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
JGee450
Sep 30, 2015 04:32 AM
