Door Sag
Old Jul 27, 2014 | 08:04 AM
WildWinter350z's Avatar
WildWinter350z
Default Door Sag
Unmolested 2003 with 30K miles. The driver side door is sagging a bit. It seems to me that it's the hinge pins as they appear worn and I can lift the door and feel slack.
Can't seem to locate replacement pins or references in the forum to this problem. Anybody have a cross-reference? Should I try to adjust the hinges instead?
Old Jul 27, 2014 | 10:44 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Welcome- are you the original owner of this particular 350Z? Door sag has not been an issue on the Z33. I'm guessing the door or hinges have been damaged in some way...
Old Jul 27, 2014 | 11:23 AM
Spike100's Avatar
Spike100
Is it sagging to the point the door does not close properly?
Old Jul 27, 2014 | 11:50 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Are the bolts on the hinges tight?
Old Jul 27, 2014 | 12:34 PM
Jennifer 2's Avatar
Jennifer 2
As Advan points out, some members here have had the door hinge bolts come loose, quite a number of them low mileage cars like yours. (Thanks Nissan assemble line workers.) The bolts holding the hinge to the door are easy to check and get at. The bolts holding the hinge to the body are harder to get to; you may even have to remove the fender. Like most cars the door hinges are adjustable, and you might only have to adjust the door up a smidge to set the world right again. The last adjustment to do is the latch striker to get perfect latching action after you have altered the door position.
Old Jul 28, 2014 | 04:49 PM
WildWinter350z
Bolts were solid up top. Pretty tight, definitely not loose on the bottom. However, after a couple iterations of some cautious loosening with a 12mm wrench and a floor jack for stability (not force), it's making that sweet sounding thunk as it shuts perfecting center on the latch striker.
Thanks all for setting me straight and sending me after the bolts.
Siqcology
Sep 18, 2019 01:45 PM
jlc280z
Sep 24, 2015 08:43 AM
Mikey R6
Sep 19, 2015 01:48 AM
roadmax
Sep 12, 2015 05:55 PM
AP350z223
Sep 8, 2015 04:38 PM
