A/C not working. Need advice!
Old Sep 6, 2014 | 11:53 AM
TheBlue350z's Avatar
TheBlue350z
Default A/C not working. Need advice!
hey guys, my a/c is not blowing out any cold air. The compressor does not turn on. I did check the refrigerant, which it is full. I was looking to replace the a/c pressure sensor, which is pretty in expensive. If the a/c pressure sensor was not working could that cause the compressor not to turn on and then not blow out cold air? If that is the case I will try it, but what are the instructions on how to remove it. Can I just simply un screw it, or do I need to remove the refrigerant out first. thanks
Old Sep 7, 2014 | 10:41 AM
laurentj23's Avatar
laurentj23
Does the fan came on at all?
Old Sep 8, 2014 | 06:03 AM
TheBlue350z
yes the engine fan turns on
Old Sep 8, 2014 | 06:10 AM
92K1500's Avatar
92K1500
How did you check the refrigerant level without the compressor running?
Check fuses first.
Have you checked for power to the compressor clutch with the a/c turned on (much easier/safer if you have the key in the on position and the engine off)
I don't know about on the Z but there is usually a high and a low pressure switch. Either of them could be bad.
If the fan kicks on with the a/c button then your fuses/relays should be good.
Old Sep 8, 2014 | 09:23 AM
TheBlue350z
Check fuses first.
i bought an a/c recharge kit at autozone. i hooked it up to the low side and the gauage was reading at full.
where is the fuse located?
Old Sep 8, 2014 | 10:21 AM
92K1500's Avatar
92K1500
The fuses are in the driver side kick panel and under the battery cover in the little boxes around the battery.
Old Sep 8, 2014 | 12:05 PM
TheBlue350z
i checked all the fuses. they were all good
Old Sep 8, 2014 | 12:28 PM
92K1500's Avatar
92K1500
I would move on to checking to see if you have power and ground to the plug at the compressor with the key on, engine off and a/c turned on.
If you have power but the clutch doesn't engage you have an a/c clutch failure.
If you have no power check all the sensors on the a/c system.
Old Sep 8, 2014 | 01:11 PM
KornerCarver's Avatar
KornerCarver
It might be a good idea to take your Z to a mechanic to have the A/C checked.
Miguel Albanez
Oct 17, 2022 10:13 AM
liqalu04
Jan 2, 2022 12:58 PM
BumbleZee
OZOC (Orlando Z Owners Club)
Sep 26, 2015 01:00 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
