2006 oem clutch master/slave
Old Sep 22, 2014 | 10:54 AM
stinkytofuz's Avatar
stinkytofuz
Default 2006 oem clutch master/slave
Hi guys,
I'm having the clutch sticking issue in which the pedal does not always come all the way back up. I've done a search and it looks like it could be the master (and/or slave) cylinder. I've already tried changing out the fluid too.
My question is, if i replace the cylinder(s), should I stay away from OEM? I dont want to have to replace it only for the issue to pop up again (no pun intended). Has nissan done anything to fix the replacement part?
Old Sep 23, 2014 | 12:50 PM
stinkytofuz
Anyone?
Old Oct 16, 2014 | 03:13 PM
90nissanS13's Avatar
90nissanS13
Default Similar issue
Have you solved your issue yet?
Old Oct 16, 2014 | 04:35 PM
PDX_Racer's Avatar
PDX_Racer
I replaced both -- although mine was most likely the seals at the slave cylinder.
Replace the slave cylinder first (external slave is VERY convenient) and make sure that the clutch line is fully bled.
Old Oct 18, 2014 | 09:31 AM
Doggman9's Avatar
Doggman9
I had the sticky clutch issue. Replaced fluid and rebuilt the master for $25. Doesn't stick anymore but when it gets really hot outside (90+ degrees) it does seem to act up very slightly. My guess is that I will end up replacing the slave eventually but it has been fine for about 2 months and counting.
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
