radiator fans not running with a/c on
Old Oct 18, 2014 | 12:06 PM
potato's Avatar
potato
Default radiator fans not running with a/c on
I noticed my car getting hot the other day and the fans didnt kick on at all. Today I turn the car on, turned the a/c on and neither fan came on. With my hand I spun both of them and only the driver side kept going. Does it sound like my fan motors are done or could it be some sort of relay/fuse?
Old Oct 19, 2014 | 12:00 PM
potato's Avatar
potato
bump
Old Oct 19, 2014 | 12:15 PM
92K1500's Avatar
92K1500
Do they turn on fine with the engine getting hot?
Seeing that it stayed running when you spun it lets us know there is power going to it.
Fans are probably dying.
Old Oct 19, 2014 | 01:33 PM
potato's Avatar
potato
no they wont come on when it starts to get hot. its probably the motors, i just hoped it was something easier
Old Oct 19, 2014 | 01:42 PM
92K1500's Avatar
92K1500
Yep. Sounds like they are going out and the one only has a dead spot since it picked up when you spun it.
I would pull them out and bench test them to verify they really are bad before dropping the cash on new fans.
Old Oct 20, 2014 | 08:18 AM
onebluezee's Avatar
onebluezee
I am having the same exact issue, none of my fans are turning on but when I push them with a screwdriver they begin to spin on their own but they seem to be spinning slow to me.
At first my radiator went bad, (the top plastic part of it literally blew up) so I replaced that, along with the thermostat, upper and lower radiator hoses, and radiator top. I bleeded the whole system to avoid the gasses, then took the car for a test drive. The temperature was just fine for about 10 minutes, then I noticed the car starting to get hot, only to realize that I installed the lower radiator hose incorrectly which caused one of the pulleys to rub against it and severed it :banghea. I changed out the lower hose, bleeded the system again, turned on the car, turned on the heater, and it was blowing hot air which was a good sign. I then took the car out for a test drive, and the temperature was normal. I then parked the car and kept it on to see if there would be a change in temperature. I had my wife keep an eye on the temperature while I looked under the hood to see if the fans had finally turned on, and they did not. I then pushed them with a screwdriver like I stated previously and they began to run. A couple minutes later the temperature on the car began to climb.
I have a feeling the fans are bad because they aren't turning on at all on their own. I checked the fuses and they look just fine. Any help would be greatly appreciated.
apex locator
Jul 23, 2021 02:27 AM
SharX59
Sep 30, 2015 10:54 AM
