HELP - P0420: Catalyst System Efficiency Below Threshold (Bank 1)
Old Nov 4, 2014 | 08:12 AM
MDQBoX's Avatar
MDQBoX
Question HELP - P0420: Catalyst System Efficiency Below Threshold (Bank 1)
Not sure if this is in the correct forum, but here goes . . .
I received a Service Engine Soon light this morning. Connected my bluetooth ODBC, ran Torque for Android application, and received this error code:
"P0420: Catalyst System Efficiency Below Threshold (Bank 1)"
I tried researching it online (google) but really couldn't find much regarding diagnosing the cause, specifically on a 2008 350Z (if that matters).
I thought I would post it on the forums and tap into the wealth of information and experience in this community.
What steps should I take next on determining the cause and/or what do you think the problem is?
Thank you.
Old Nov 4, 2014 | 08:27 AM
jhc's Avatar
jhc
General & Tech Moderator
You can probably get around it if you clean your fuel system (Techron is good),
also make sure plugs are good.
Some reading for you-
https://www.google.com/search?btnG=1...50z&gws_rd=ssl
Old Nov 4, 2014 | 08:33 AM
iideadeyeii's Avatar
iideadeyeii
2ND o2 sensor is reporting an error. If you have the stock exhaust either there is a leak between first/2nd o2 sensor (bank1 meaning side where cylinder 1 fires) cat is bad or sensor is back.
Old Nov 4, 2014 | 09:07 AM
MDQBoX's Avatar
MDQBoX
-All I ever use is Chevron/Texaco, that has the techron in it. I will try a fuel system cleaner. Also, I changed the plugs and air filters about 3-5K miles ago. Thanks.
-I do have the stock exhaust system installed. Everything is stock. I'm assuming checking the O2 sensors will require me to take it to to a shop/mechanic since I don't have the equipment. . .?
Thanks for the prompt and helpful responses.
Old Nov 4, 2014 | 01:20 PM
sikkntbrah's Avatar
sikkntbrah
i had a code come up about a year ago and i have a 2008 but i dont remember exactly which code, but turned out my driver side cat went bad.
someone can correct me if im wrong but i believe we have an 8 year warranty on anything emissions related. i took it to the dealer and got a new cat, no charge. so that could be an option for you.
Old Nov 4, 2014 | 02:19 PM
MDQBoX's Avatar
MDQBoX
I will definitely be looking into this. Thanks for your input.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
