Loctite Red or JB Weld?
Old Dec 4, 2014 | 05:29 AM
JMSpeed's Avatar
JMSpeed
Default Loctite Red or JB Weld?
I replaced my rear shocks and used the FSM recommended torque on the 2 upper mount nuts of 20 ft lbs. One side worked out fine, the other appears to have stripped the threads on the bolt or the nut since the nut just keeps turning.
I'm not sure if it's the nut or the bolt that stripped, but after reading through some other threads it appears the bolt is most likely to be the culprit. Seeing as how I'd have to replace the bolts entirely with some custom pieces, my thought is to weld the nuts in place now and deal with it in another 5 years if and when the shocks need to be replaced. The shocks appear to be stable and in place currently.
Thoughts on my options?
Old Dec 4, 2014 | 05:48 AM
dkmura's Avatar
dkmura
General & DIY Moderator
If you've stripped the bolt, it's going to be a problem. You should be able to see the bolt threads themselves and determine if they're gone. If it's the bolt, then it's an easy fix. But I wouldn't trust either JB Weld or Loctite to properly locate the shock mount.
I'd opt to replace the stripped bolt myself, it's gonna be a PITA, but it's the best solution. This thread also serves to warn those DIY noobs to watch out on wrenching on these delicate studs (and use a torque wrench for God's sake)!
Old Dec 4, 2014 | 06:07 AM
JMSpeed's Avatar
JMSpeed
The threads are covered by the bolt, so I can't tell entirely. And I used a torque wrench, so I'd add to your suggestion that don't completely rely on the wrench. Feel it out slowly. My bolts/nuts were fit for the proper torque on one side but not the other.
Old Dec 4, 2014 | 06:41 AM
iideadeyeii's Avatar
iideadeyeii
Strip a slightly smaller coarse standard size bolt on it and call it a day.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
350z82
Oct 1, 2015 06:25 PM
