6MT trans issue
Old Jan 9, 2015 | 04:53 PM
trxdd's Avatar
trxdd
Default 6MT trans issue
Issues
  • Mechanical whir sound while in 1st gear
  • Strong vibration in 1st coming from gearbox under hard accel
  • If I go from 2nd to 6th after hard acceleration it'll grind, so synchros probably going out
I've got an aftermarket warranty and plan on taking it into the Nissan dealership or another shop shortly. I have a few questions though..
Questions
  • How do you check the 6MT trans fluid level? I'm worried that it could be low, and then they may refuse to honor the warranty
  • Based on my symptoms..do you think the synchros is going out? Flywheel? First gear?
  • How much do you think Nissan will charge to "diagnose" the issue? I have to pay that out of pocket, as well as taxes
and totally unrelated, but how much is it generally to repaint a front bumper? had an incident in a tight spot in a parking garage..
Edit: Is AAMCO a bad place to go for transmission work?
Old Jan 9, 2015 | 05:10 PM
tommy smith's Avatar
tommy smith
Default I'm watching tv home on a cold night
Originally Posted by trxdd
Issues
Questions
I just don't think I'll find any show as entertaining as your post Thank you.
Old Jan 9, 2015 | 05:40 PM
trxdd's Avatar
trxdd
aww shucks ;~)
but what part is making you laugh? I don't know anything and it's sad
Old Jan 10, 2015 | 09:32 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Answers:
-Jack up and support the Z level on four jackstands. Underneath the tranny, you'll find two plugs. One is to drain and the one on the side to fill. To check the correct fill level, remove the fill plug and feel with you finger. The fill level should be to the botton of the fill hole.
-Speculating on driveline problems does little good. Only a hands-on inspection (and possibly disassembly) will reveal the true nature of your problems.
-Nissan dealerships vary in their charges from state-to-state. Most will charge at least an hour of shop time to start the diagnostic. My local dealer charges $130/hr- you should ask about shop charges at your dealer.
Old Jan 10, 2015 | 09:55 AM
trxdd's Avatar
trxdd
Originally Posted by dkmura
Answers:
Thank you, I'll check the fluid. I'll also have to swing by Nissan and ask how much they charge for diagnostic time.
Is AAMCO a bad idea for transmission work? I've heard bad things about them..
Old Jan 10, 2015 | 10:10 AM
dkmura's Avatar
dkmura
I'd look for a Nissan specialist in your area for trnny work. Check with the dealership on whether your aftermarket warranty is honored there.
sherm
Apr 11, 2020 05:21 PM
Stevo Z
Oct 3, 2015 09:14 PM
350z82
Oct 1, 2015 06:25 PM
