Replacing the battery terminals
Old Jan 11, 2015 | 08:37 AM
llurz1's Avatar
llurz1
Default Replacing the battery terminals
I got a new battery and when I was tightening down the terminal with the fuse box I accidentally snapped the terminal. I'm trying to get a new terminal to install but am confused as to what to get because of the fuse box. Anybody know? Thank you.
Old Jan 13, 2015 | 05:52 AM
VengefulHitman's Avatar
VengefulHitman
I had to do this yesterday, its actually really easy.
after you disconnect the battery, remove the nut that the red arrow is pointed to. after the nut is off you can detach that positive terminal connection. it might be a little tricky to get off but it can be done. it looks like you can get an OEM replacement from here
http://www.thenismoshop.com/Nissan-F...0-_p_1026.html
for a temporary fix or if you aren't pressed about an OEM replacement you can just go to an auto parts store and the people can direct you where to go. look for a universal battery terminal end that looks similar to the OEM part with that vertical bolt that will connect you to the harness. I think the one that I bought was $6-7.
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
