How do I remove the pcv valve?
Old Mar 19, 2015 | 07:00 PM
carson310's Avatar
carson310
Default How do I remove the pcv valve?
I'm trying to replace my pcv valve, I tried removing it but had no luck. Is there any guides on how to do it yourself? Thank you
Ps. I tried searching the forums about this topic but couldn't find any.
Old Mar 19, 2015 | 07:41 PM
woody03's Avatar
woody03
How were you trying to remove the valve?
Old Mar 19, 2015 | 09:32 PM
carson310's Avatar
carson310
Default Reply
There is this hose that I can't seem to remove from the pcv valve. Is this really that tough to remove or there's a special way or technique of removing the hose? Its really hard to pull it out the pcv valve
Old Mar 20, 2015 | 06:17 AM
woody03's Avatar
woody03
It can be tough to get the hose off but there is no special way. Just pull.
Old Mar 20, 2015 | 11:16 AM
carson310's Avatar
carson310
ok thanks guys really appreciate the help!
Old Mar 24, 2015 | 11:11 AM
absolutfrase's Avatar
absolutfrase
Squirt a little silicon-based oil down the hose allowing it to run to the pvc. A little twisiting & tugging should get it to pull off. The excess silicon oil will make sliding the new pvc in easy.
apex locator
Jul 23, 2021 02:27 AM
Rev_Night
Nov 7, 2020 06:00 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
