clutch sticking halfway
Old Apr 5, 2015 | 05:15 PM
Keepitclean's Avatar
Keepitclean
Default clutch sticking halfway
After driving about 20 miles and it's warm out my clutch pedal doesn't come up all the way. Shifting starts to feel rough and sometimes doesn't want to go into reverse. Any ideas? I'm thinking clutch master and/or slave cylinder. I'm gunna start by changing both
Old Apr 5, 2015 | 05:44 PM
Freise's Avatar
Freise
It could possibly be the fluid itself, might have boiled air bubbles into it. You may want to try bleeding fluid before just throwing money at parts.
Old Apr 5, 2015 | 05:45 PM
oldschool350z's Avatar
oldschool350z
Could be any of those three.
Old Apr 5, 2015 | 05:47 PM
travlee's Avatar
travlee
Master
what is the year of the car?
Old Apr 5, 2015 | 05:51 PM
Keepitclean
It's a 2006 and that's what I originally thought but a friend of mine was saying it's probably the master cylinder. I'll give that a shot when I get a chance
Old Apr 5, 2015 | 05:54 PM
travlee's Avatar
travlee
Master
it is best to replace the master and slave together, since yours is external it will be easy. not to mention when you take the slave off all the fluid is going to drain out, you will be putting in fresh stuff, so all three things will be covered
Old Apr 5, 2015 | 06:40 PM
Keepitclean
Think that'll fix the problem?
Old Apr 5, 2015 | 09:23 PM
terrasmak's Avatar
Master, very common, $20 rebuild kit and good to go,
Old Apr 6, 2015 | 07:58 AM
ricardoreyes626's Avatar
ricardoreyes626
I had the exact same problem after I replaced my clutch on my 2004 z. all I had to do was bleed out the clutch and boom problem fixed. I just drove it all the way to Mexico and the problem didn't happen again.
Old Apr 6, 2015 | 08:20 AM
Syner's Avatar
Syner
Yes.
Old Apr 6, 2015 | 11:06 AM
blue06z's Avatar
blue06z
Replace the clutch line. Several companies make a braided line.
Old Apr 6, 2015 | 01:26 PM
Escobar's Avatar
Escobar
if your certain it doesnt have bubbles in it then its probably the master cylinder and or slave. what year car and how many miles? I'd replace both and upgrade to the stainless line. check out czp. Make sure you follow the fsm exactly or look up my thread on how to bleed it right or you will be pumping the brake pedal for hours. E
Old Apr 6, 2015 | 03:59 PM
Keepitclean
2006 60k do u have a link? Not too forum savy lol
Old Apr 7, 2015 | 05:10 AM
trusovici's Avatar
trusovici
replace master and slave. when bleeding make sure to crack all the fittings to let air out. alot of times air gets trapped by banjo bolts etc.
Old Apr 7, 2015 | 05:37 AM
Escobar's Avatar
Escobar
https://my350z.com/forum/maintenance...ed-clutch.html
Old Apr 7, 2015 | 08:44 PM
Keepitclean
Thank you to everyone appreciate it
Old Apr 8, 2015 | 09:25 AM
Escobar's Avatar
Escobar
good luck bud.
Old Apr 19, 2015 | 11:18 PM
Golden_Armz's Avatar
Golden_Armz
My 06 does that too on hot days. The clutch pedal makes a clicking noise. And during the summer sometimes I have to use my foot to lift the pedal back to normal. I've read that its your master cylinder, but should replace slave also. Its not an expensive fix so mind as we'll just do both.
Old Apr 22, 2015 | 02:46 PM
Keepitclean
Yup that is 100% accurate to what it does changing both would stop the clicking too?
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
