350z coolant level at min
so I had my coolant flushed and changed a month ago. I looked at the coolant level for the 1st time after the flush and its at min. the car is still kinda hot. does the coolant level change as it gets hotter or colder? should I add more into it??
If it's just a low level in the overflow tank, pour in some water. It's normal for the tank to be a little low after a coolant flush/refill as air bubbles work their way out of the system, and as the system cools, coolant to replace that air is drawn in from the overflow. That's why it's there. If it happens again, start looking for a leak in the system.
Just an FYI in case it ever happens again (hopefully it doesn't). If you do decide to add water, make sure to add distilled water. don't add tap (it's not a huuuuuge deal but just another precaution you can take). tap has a lot of stuff in it that would be better of not in your engine. Cheers!
He's in Canada. He will add coolant, not water.
bcoffee20
Nov 19, 2015 06:39 PM
hardkicks
Sep 20, 2015 12:28 PM
