Passenger Electric Seat not working!! WHY??!
Old Apr 26, 2015 | 12:10 PM
D_Rod's Avatar
D_Rod
Default Passenger Electric Seat not working!! WHY??!
So I got new leather seat covers for my Z and I removed and unplugged the PASSENGER electric seat connections from the bottom, removed the seat, changed the seat covers, and placed the seat and connections back onto the car correctly. But now the slide forwards and backwards electric adjuster doesn't work.
I'm sure I plugged everything back the same way. Could the motor gone out? I didn't see a specific fuse for electric seats. Is there possibly a funky way or resetting electric seats or something?
Can't fit a passenger anymore if I can't slide the seat back
Any help would be awesome.
Old Apr 26, 2015 | 12:19 PM
blue06z's Avatar
blue06z
Sounds like you bent a pin in the connector.
Old Apr 27, 2015 | 11:46 AM
shadowoffair's Avatar
shadowoffair
You possibly could have done what he said. My driver electric seat wouldn't recline forward, only slide back and forth. I took the seat out, took the switch off, and took the circuitry apart. Found dirrty contacts and cleaned them up with some high grit sand paper. Your other option is your motor finally gave out too.
Old Apr 27, 2015 | 11:56 AM
bith8791's Avatar
bith8791
Not long ago my driver seat would not return to an upright position after being reclined, it would only slide front to back, it mysteriously started working again, I used some electronics cleaner on the switches and it hasn't given me any problems since, I would try using some electronics cleaner on the switches.
Old May 11, 2015 | 10:43 PM
D_Rod's Avatar
D_Rod
Thanks for your help. Stupid me, I accidentally tucked a power cable in with the new seat covers. I had to remove the seat covers and find the cable again. Thanks for the input. Here's an image of my before and after work I did.
Old May 13, 2015 | 05:14 PM
shadowoffair
Wanna do mine?
Old May 14, 2015 | 08:57 PM
Tony1M's Avatar
Tony1M
What covers did you get and how do you like them?
Old May 24, 2015 | 07:23 PM
D_Rod's Avatar
D_Rod
lol. I'd like to but they're a pain to install. Took me the entire weekend to do both seats.
Originally Posted by shadowoffair
Wanna do mine?
Old May 24, 2015 | 07:25 PM
D_Rod's Avatar
D_Rod
I got them from www.LeatherSeats.com. They are expensive but they are all worth it if you love your Z that much. About $670 for driver and passenger seat covers. You can customize the color patterns and stitching colors too.
HoBrahYouStink
Jun 24, 2016 10:58 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
samansharif
Sep 25, 2015 12:31 PM
