Z leaking air
Alright before I get flack for not searching, I found a thread with my exact same problem but with no solution (Link: https://my350z.com/forum/maintenance...er-window.html)
So my question is, what kind of problem is this? Window stripping? Regulator? Motor?
Just want to know before I go about buying parts that won't solve this issue.
I've read once before that these seals wear out and rip. Mine need replaced but I haven't gotten around to it yet.
http://www.courtesyparts.com/80830a-...8-p-18412.html
http://www.courtesyparts.com/80831a-...8-p-18415.html
Thanks for the help, does anything think it could be the regulator? I'll be driving down the highway and the window will just slightly roll down like a millimeter but you can hear the air streaming through. Also, had where I was getting a car wash and the water came in through my tweeters which gave me a scare.
I need to do the relearn on my windows again or see what's dragging. Just replaced my window motors and my driver window just barely drops enough to clear the A pillar cover but the passenger window wont drop at all. It goes slack and you can push it down but it wont pull itself down.
And the seals I linked above are old and worn so they leak.
I reset my driver window then it went funny again a day later. I just replaced it 2 days ago, did the reset and i haven't looked back. My windows actually role up enough to make a water tight seal but still clear the A-frame to open the door when the pinch function didn't work correctly.
Replace the motor if that is what you think is causing it vs a bad seal. It will save you time in the long run.
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
