Hello people, Recently i pressure tested my oil. That being said when i put back my sensor i accidentally torqued it a bit too much, and cause the sensor area to crack. Right now i just JB Welded it with Marine Weld just to get it home from where it was. I know the oil heat will melt the jb weld so my next option is to just replace the upper oil pan.
Which is a better more efficient way to remove and replace the oil pan? From down under or to just take out the whole motor.?
