03' 350z not cranking
Old May 3, 2015 | 02:37 PM
Jason 03 350z's Avatar
Jason 03 350z
Default 03' 350z not cranking
hello everyone, I need some help. my 03 350z will not crank, It does not seem to be the battery, all lights work and the volt meter shows no drain when I turn the key. I unplugged the clutch safety switch and jumped it with a wire to rule it out. bought, replaced the starter and solenoid still no luck. I heard that the intelligent power distribution module could cause this but I don't know how to trouble shoot my IPDM. any other ideas or help would be appreciated.
Old May 4, 2015 | 07:39 PM
shadowoffair's Avatar
shadowoffair
It may be your key. Have it tested if possible.
Old May 4, 2015 | 08:00 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Welcome- your Z is equipped with an onboard diagnostic system accessed through the OBD2 plug. Use a code reader to gain some definitive answers to your 'no start' problem.
Old May 5, 2015 | 01:43 AM
Jason 03 350z
When I turn the key I get 12 volts to #11 wire on the IPDM but on wire #4 it jumps from 0 to 3volts then back to 0, pretty sure it is the starter relay or connections on my IPDM but I will check the key, I think the security light on the dash stays lit solid when I turn the key which is an indication that the key is good but om not sure, thank you for your input.
Old May 5, 2015 | 01:46 AM
Jason 03 350z
I will check for new codes thanks.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
