Passenger side floor mat wet after rain. Help!
Old May 17, 2015 | 06:30 PM
Stevefromsd's Avatar
Stevefromsd
Default Passenger side floor mat wet after rain. Help!
My 2004 350Z Roadster's passenger side floor mat was wet after driving in the rain last week. The top isn't leaking so I know that's not it. I didn't even know the floor mat was wet until it smelled like mildew the next day. I also had a few drops of water fall on my left leg while driving in the rain another time but it was only a few drops. Any idea why there is a leak on the passenger side? It's supposed to rain tomorrow too... Is there a place other than the dealer that can fix it? I can only imagine what the dealer will charge.
Old May 18, 2015 | 10:57 AM
icer5160's Avatar
icer5160
The most obvious culprit would be the top, if you can guarantee that's not leaking, then check the passenger side door weather stripping, especially the area that seals off the window.
If only the carpet/floor mat was damp/wet and not the seat, then you may have a floor pan leak somewhere. You will need to pull up the carpet to solve that one.
Old May 18, 2015 | 12:39 PM
zakmartin's Avatar
zakmartin
Check to see if you have any loose or broken grommets on the firewall in the area around the leak. Also, check to see if your passenger side rearview mirror is loose. If it is, tighten it up. A good way to check for leaks is to remove the passenger seat, pull the carpet back, have a friend run a hose against the car when it's dry out (start at the top and work your way down) and when it starts to drip, you're in the right place.
Another possibility is that the evaporator drain spout is clogged and needs to be blown out (check for dampness around the blower motor housing area).
(edit) Be sure to disconnect your battery and wait 20 minutes if you're going to pull the seat out, since you'll be unplugging your airbag harness.
Also, check the cowling under the hood to see if there's any crud from trees, bugs, etc. clogging the drain holes. If there is, water could conceivably back up in the cowling area during a rain storm and cause water to pour down your fresh air intake, causing a puddle in your passenger floor area.
Old May 21, 2020 | 05:04 AM
Pelicanpirate's Avatar
Pelicanpirate
Hi, how could you prevent water draining through the fresh air vent. Mine is just a cross wire covered opening in that shelf under the cowling.I was thinking of running some same size ducting from it to the area below it....water cant flow uphill can it ?
Old Oct 10, 2025 | 04:03 PM
Anthem350z's Avatar
Anthem350z
Does anyone know how to access the drain tube behind the passenger side seat? I have a puddle at the back right of my passenger seat, I suspect its the Vinyl Tube (C-Link Bottom End Bracket), located on RF-102 in the manual. It carries rainwater from the drain funnel at the rear corner of the convertible top down through the body to the exterior. Or if you have an image of it.
silvertouringz
Feb 6, 2021 02:13 PM
joeyz12
Oct 8, 2015 01:37 PM
pyropete
Dec 18, 2007 10:06 AM
aggie05
Sep 20, 2006 09:41 AM
mirage2130
Apr 21, 2005 09:16 AM
