ECU Compatibility
Old Jul 8, 2015 | 12:10 PM
Paulius923's Avatar
Paulius923
Default ECU Compatibility
ok so i have a problem my ecu fried.
My Ecu is MEC60 132 A1 6405
I found one on ebay thats MEC60 132 A1 6420
Would it be compatible, and if it would, would still need to programme it?
Old Jul 8, 2015 | 12:21 PM
dkmura's Avatar
dkmura
General & DIY Moderator
First off, how do you know your ECM is "fried" and totally unrecoverable? Nissan can reprogram an ECM using a CONSULT III unit if it's not totally blasted...
I doubt anyone here has the knowledge or ability to pull up part # and determine if they are compatible parts. Your best chance would be to determine what year and Z33 model it came out of. Manual vs. auto would be another critical factor to match up. So if I were looking for a replacement ECM for my '03 track model, I'd look for an ECM out of an '03-05 GT, track, touring or performance model that came with a manual tranny.
Old Jul 8, 2015 | 12:30 PM
Paulius923's Avatar
Paulius923
Well my TCS slip lights are on the fans run when ignition is on, cant reset the ecu through cars SEL mode. Cant erase codes through obd2 and my mechanich just checked and said the same thing, so im pretty sure the ECU is fried.
Also the part number i gave you only comes in 2006 models.
The only thing i really need to check whether it came form auto or manual.
hulkout
Tuning
Sep 30, 2015 12:33 PM
SharX59
Sep 27, 2015 09:23 AM
