idpm replacement
Old Oct 13, 2015 | 04:22 AM
kartkid's Avatar
kartkid
Default idpm replacement
I am having trouble with my fans not operating.
I have checked the fans and both work fine when powered up
I have checked all fuses and tested all I can.
I feel it is a faulty relay but they are non replaceable on the idpm board.
I can pick up a known good one.
But some say it will need reprogramming
I can get one from the same year and from a auto trans as mine so do I still need to take it to a dealer to be reprogrammed!
and if so why?
Old Oct 13, 2015 | 07:54 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Don't have any idea on reprogramming for an IPDM, but I'd question whether it needs to be replaced. Have you had any electrical surge issues or water intrusion that makes such a failure likely? IPDM failures have not been a regular problem with Z33s.
Are there any codes being thrown to indicate an IPDM failure?
Old Oct 14, 2015 | 12:42 PM
zakmartin's Avatar
zakmartin
Here's a thread discussing this very topic:
https://my350z.com/forum/maintenance...-bad-ipdm.html
Old Oct 17, 2015 | 05:47 AM
kartkid's Avatar
kartkid
Thanks I have just ordered a used one same year and with same trans.
I will update after I get it in.
Old Dec 19, 2015 | 11:30 PM
EZ-e's Avatar
EZ-e
Unhappy ipdm issues
hi all, im really having an issue understanding on how to fix just about any problem with the IPDM. my tail lights and side markers and running lights are out and i cannot figure this thing out. i have replaced all fuses bulbs etc. but still no tail lights. is this something i can order a replacement ipdm box all together and just do it myself or is this something i absolutely need to take to a dealership or shop. plz any and all help is welcomed. plzzZ help .
Old Dec 20, 2015 | 08:29 AM
dkmura's Avatar
dkmura
Any kind of IPDM problems are usually serious ones. If you've checked the simple things like fuses and connections, and you are still getting codes involving multiple IPDM related codes, it's time to get a ctory tech involved. Throwing various parts at a problem is definitely NOT a solution.
It says something when the OP on this thread still hasn't posted any updates on his IPDM issues.
Old Dec 20, 2015 | 02:36 PM
EZ-e's Avatar
EZ-e
im not throwing any codes though. i have replaced fuses,bulbs, rechecked with oem radio in. problem started when i put led bulbs in. now for refrence the top light is your breaks and bottom light in the tail light casing is your tail light correct? plz correct me if im wrong. could it be a grounding issue and if so what steps should i take to check the grounding?
Thanks in advanced1
vertico
Nitrous Oxide
Nov 15, 2015 07:04 PM
HRMoneyPit
Southern California
Oct 20, 2015 12:45 PM
gossf
Oct 12, 2015 04:43 PM
BIGPOPPAPUMP
Oct 8, 2015 11:59 PM
