Help with RevUp engine!
Old Dec 15, 2015 | 03:42 PM
Jawwed's Avatar
Jawwed
Default Help with stupid RevUp motor!!
Alright guys so I got my 2006 350z 6MT 4 months ago, and about one month ago, i started to hear a bad knocking from the bell housing area, did a little research and figured out that these engines consume oil like crazy and that it was low on oil. Which was correct, so i got an oil change and that fixed.
Well now its back, my car lost 3qts of oil in one month. ONE MONTH. So i went and got an oil change and its still there. So i left it at the dealer and told them to hold off while i do research. Do you guys think i spun a bearing because it ran dry, or is there something else i can do to fix this problem? Its a repetitive knock coming from right in between the engine and tranny. Thank you guys!
Old Dec 15, 2015 | 04:17 PM
icer5160's Avatar
icer5160
A noisy bell housing is fairly normal for the 350Z 6MTs. It's just how the clutch/tranny are on these cars. While idling, leave the car in neutral and push in the clutch all the way. If the noise you're hearing quiets down a lot or disappears all-together, then It's safe to say it's just the clutch/throw-out bearing making the noise.
Now if you're consuming a massive amount of oil in such a short period of time, that is something completely different. The engine will most likely need to be replaced. I have a RevUp and I burn about 3/4qt every 1500mi which is a good amount, but easily manageable. If you're losing 3qts in one month....and the engine shows no signs of leakage anywhere, you will need a rebuild or a new shortblock.
Sounds like the dealer sold you a lemon, I hope they help you out, but legally I don't think they are obligated if it's been more than 30 days.
Good Luck!
-Icer
Old Dec 15, 2015 | 04:39 PM
Jawwed's Avatar
Jawwed
Its not the throughout bearing sadly, i wish it was lol id have the tranny out tonight. The noise gets louder with the RPMS.
Old Dec 15, 2015 | 08:55 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Seems like I'm giving the same advice all the time: get a leakdown and compression check to determine the overall health of your VQ. Without tearing the engine down, a UOA might be another way of getting an idea of what's going on inside.
Old Dec 15, 2015 | 09:00 PM
Jawwed's Avatar
Jawwed
Yeah ill do that for sure, but that doesn't go about solving the knock no matter the results
Old Dec 15, 2015 | 09:55 PM
terrasmak's Avatar
You are allowed and able to add oil between changes, very important to do on a car that burns oil. Got a knock, the damage is done. Time to tear it down and fix it or swap in another motor
Old Dec 15, 2015 | 10:48 PM
Jawwed's Avatar
Jawwed
yeah i understand i can add oil, I was watching the oil pressure every day and everything seemed fine until the one day i started it up, oh well my fault. I guess the only thing left to do is to throw money at it
Old Dec 15, 2015 | 11:11 PM
terrasmak's Avatar
Quantity and pressure are different, but you need quantity to have pressure. At rpm , it only takes a few seconds of dropped pressure to damage a bearing. The dipstick is much better than the pressure gauge.
Since you had a major consumption issue, a rebuild will be a good thing
NeoGixxer
Lighting
Dec 22, 2015 07:31 AM
absolutfrase
Nov 30, 2015 08:30 AM
MikeBit
Nov 26, 2015 11:39 AM
aXxICExXa
Intake
Nov 18, 2015 09:01 AM
aXxICExXa
Exterior
Nov 18, 2015 08:57 AM
