Parking brake help!!!
Old Jan 2, 2016 | 11:42 PM
Tessa350z's Avatar
Tessa350z
Default Parking brake help!!!
I need help finding a replacment part so I can fix my parking brake on my '03 base. When I remove the wheel and rotor I have nothing there. Previous owner I guess removed it. I don't have any way to mount a replacement kit on to the wheel hub. Is their a replacement out there? This is what I'm looking for. Like I have no way to mount the parking brake kit to my wheel.
Old Jan 3, 2016 | 04:50 AM
rancor's Avatar
rancor
You can search Google for the 350z factory service manual it should show you what parts you need, and how to assemble it.
Old Jan 3, 2016 | 12:14 PM
Blurvision's Avatar
Blurvision
Local dealer can source all the parts you may need.
Old Jan 3, 2016 | 03:22 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Does a base z come with drum brakes? Wtf nissan
Old Jan 3, 2016 | 03:26 PM
KornerCarver's Avatar
KornerCarver
dboy---All 350's come with a drum parking brake. It is built inside the back rotor. Nissan really put 4 wheel disc brakes on all the 350's.
Old Jan 3, 2016 | 03:46 PM
dboyzalter's Avatar
dboyzalter
Is it hydraulic? Im looking at the brake cylinder going wtf... Ive only ever seen the cable style...
Ive come from a long line of pick-up trucks and right now its showing.
Old Jan 3, 2016 | 07:31 PM
gtx's Avatar
gtx
I don’t know what parking brake assembly is in that picture, but it isn’t a 350Z unit.
Old Jan 3, 2016 | 09:26 PM
dcains's Avatar
dcains
No kidding. There's no cutout in the dust shield for a brake caliper, and that's a hydraulic cylinder at the top.
Old Jan 4, 2016 | 02:10 AM
dboyzalter's Avatar
dboyzalter
Thanks I don't feel so clueless now. Im half inclined to take my brakes apart just to see whats what under their now.
Old Jan 4, 2016 | 08:00 PM
Tessa350z's Avatar
Tessa350z
As previously said its a drum style underneath the rotors in the back. It's now hydrolic however your handbrake has a cable that runs all the way to the back and there's literally nothing under mine. The previous owner took them out because "it does burn outs better" some people in this world make me shake my head. But thanks for the help everyone. I have been searching in every manual I can find and every diagram as well but haven't been able to find anything. I guess a trip to the stealership is in order.
Old Jan 4, 2016 | 09:28 PM
dcains's Avatar
dcains
You're not going to find parts at a dealer to work with an aftermarket hydraulic e-brake kit, so all that needs to come off. Take a look at the courtesy parts site and just order everything from the backing plate out, assuming the cable stuff is still in place.
http://www.courtesyparts.com/auto-pa...ing-brake-scat
Old Jan 5, 2016 | 03:33 PM
RWDBajan's Avatar
RWDBajan
No junkyard in your area? You could probably get two rear hubs and just swap the parts over. Wear on the shoes is virtually squat.
Old Jan 5, 2016 | 05:25 PM
dcains's Avatar
dcains
Turbo Toys in Tampa always has parts from many salvaged Z's, so he may be able to set you up with everything you need. There can't be much demand for those parts, so haggle with him and see what you can do.
Old Jan 6, 2016 | 11:51 AM
SirSpeedyZ's Avatar
SirSpeedyZ
I was wondering what was going on with the picture, I just replaced the brake shoes on mine and they looked nothing like the first picture.
Old Jan 6, 2016 | 11:55 AM
travlee's Avatar
travlee
Master
could always check here also
http://www.slidegood.com/nissan/350z
Old Jan 15, 2016 | 06:10 AM
Tessa350z's Avatar
Tessa350z
Thanks everyone for the help. To answer most people yes I know that's not what a 350z looks like under the rear rotors I was just giving an example. But no scrapyards around for hours that would even have this car. Have all kinds of small ones in my area but I've checked them all and 90% of them didn't even know what car I was talking about. But thank you to all that helped out I really appreciate all of it.
Old Jan 15, 2016 | 06:15 AM
Tessa350z's Avatar
Tessa350z
I think I will make a trip up to a few scrap yards near St. Louis and see what I can find. Have friends that go up there and they always have one or two Z's sitting but no clue if they have the part I need. And they won't tell you over the phone either. But thanks again everyone! This forum is one of the best I've seen, everyone is very helpful!
Old Jan 15, 2016 | 07:05 AM
dboyzalter's Avatar
dboyzalter
http://hartford.craigslist.org/pts/5369152988.html
http://worcester.craigslist.org/ptd/5343453234.html
Give this dudes a try... Good luck
josephscaturro
Jan 4, 2016 02:10 PM
pondera
Jan 2, 2016 05:17 PM
Smokey Bear
Jan 1, 2016 07:04 PM
