Please Help!! What kind of oil leak is this?
Old Feb 23, 2016 | 04:57 PM
Juanvelez1962's Avatar
Juanvelez1962
Exclamation Please Help!! What kind of oil leak is this?
Hi i just found this on my car:
1) What part seems to be leaking, and what is the fix?
2) Is it expensive to fix?
3) If my oil level doesn't drop could i ignore this and just keep checking the oil level regularly?
Thanks please help.
Old Feb 23, 2016 | 05:24 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
guess is valve cover gasket
Old Feb 23, 2016 | 06:02 PM
Juanvelez1962
Thanks, could i let it like that if my oil level doesn't drop?
Also could this be a rear main seal leak?
Old Feb 24, 2016 | 07:40 PM
guitman32's Avatar
guitman32
Valve cover gaskets. Remove and replace.
No.
Yes, but not recommended. Although the oil will burn off the headers as you run the car, if love your Z it will love you back.
Old Feb 25, 2016 | 01:37 AM
Surfer90291's Avatar
Surfer90291
Money on valve cover gasket as well.
How much oil are you losing? As long as you keep topping up as needed.
Old Feb 25, 2016 | 11:43 AM
Juanvelez1962
I lose like 1/4 of a 1 QT bottle every 3 or 4 months.
Some of it cold be consumed also, not dropped
Old Feb 25, 2016 | 11:54 AM
iideadeyeii's Avatar
iideadeyeii
I would fix since it's getting on the exhaust. On a beater car I wouldn't though
Old Feb 25, 2016 | 03:14 PM
KJFire4Life's Avatar
KJFire4Life
As a note.....If you are not comfortable taking a ton of wires out and pulling the plenum/intake off take it to a shop. But even the most base DIY mechanic can do this. It may seem daunting but I promise you it's not If you need some pointers just give me a shout on PM. Expect to do Spark plugs while you're down there, not worth it to take it all apart and not do them lol. My Z was leaking oil pretty bad from VC's when I got it and smelled constantly. Ever since I fixed her she's been happy and not smelling anymore
Old Feb 25, 2016 | 03:30 PM
Juanvelez1962
Thanks, what i am most concern if i would do it myself is moving the fuel and coolant lines inside the plenum.
I had changed the spark plugs and coil boots like 1700 Km ago so i would let the same.
I ordered the valve covers already to have them changed instantly if i see the leak gets worse, i asked today how much would it cost me to have them changed in a very good shop, and the say they would charge me about 120 US dollars, i live outside USA, shops are less expensive here.
I will also change the knock sensor and harness if i change the valve covers, since i got a code on it, even tho my cars feels fine on power and fuel consumption, but it would be a waste not to change it if i am already so close to it.
Old Feb 26, 2016 | 12:23 PM
Surfer90291
Can you quantify the miles of your 3/4 months? It's a negligible amount, if it doesn't get worse I would do NOTHING!
Old Feb 26, 2016 | 03:25 PM
Juanvelez1962
Like 600 Miles every 4 months, the car is my daily driver, but i live very close to work.
Old Feb 27, 2016 | 01:45 AM
Surfer90291
That means 1/2 qt over 1200 miles, just top it. I'd probably change the oil a couple times a year at least anyway.
Old Feb 27, 2016 | 06:32 PM
Juanvelez1962
Thanks, i'll do that, i will buy the gasket covers just in case it gets worst to change them immediately
Old Feb 28, 2016 | 01:54 PM
rich2342's Avatar
rich2342
I am burning/leaking pretty well. I noticed old oil residue buildup on the sides of the plenum. Would oil leak out of the plenum, should it not be there in the first place?
Old Mar 1, 2016 | 01:41 AM
KJFire4Life
Our cars LOVE pulling oil through the intake with rev's.....That's why they make oil catch cans to hook up inline with the PCV valve. If you are seeing oil buildup on the sides of the plenum. You might want to pop your upper plenum and see how much is built up in there?
Old Mar 1, 2016 | 01:43 AM
KJFire4Life
I know it doesn't seem like a huge problem. But think about this, you're constantly, however slow, dripping oil into your engine and engine bay........That's going to not only smell bad over time but create a grimy mess and reduce engine quality/life. You take care of your car and they'll take care of you! Or if it's just a beater.......then run it into the ground lol
Old Mar 1, 2016 | 04:13 AM
verdict.'s Avatar
verdict.
Threads merged...
Extreme Dimensions
Body Exterior
Jun 7, 2016 03:17 PM
ipodhustle
Feb 26, 2016 11:21 AM
rich2342
Feb 25, 2016 04:28 PM
ryanjarosz63
Feb 22, 2016 04:09 PM
EnjukuRacing
Body Interior
Feb 19, 2016 07:48 AM
