Help diagnosing throwout or pilot bearing noise (video link)
Old Feb 22, 2016 | 10:48 AM
nicoZ's Avatar
nicoZ
Default Help diagnosing throwout or pilot bearing noise (video link)
Hi all, I've searched the forum for this but I can't seem to find a scenario that is the same as mine. My car is making a squealing noise which almost sounds like a squeaky belt pulley but it is not.
This noise seems to come start and stop at completely random times.
In the video you see it go away when the clutch is disengaged (press pedal) but if you wait until the end of the video the noise remains with and without the clutch pedal pressed. Normally pressing the clutch pedal will do nothing to remove the noise but in this particular video it did at some point. I know this would indicate the throwout bearing or in my case the CSC (I have an HR) but the noise happens many many times with the clutch disengaged. I am leaning towards pilot bearing but has anyone had this noise before? Maybe it isn't even a bearing at all?
All help is greatly appreciated!! Below is a link to the video.
Old Feb 22, 2016 | 01:23 PM
dkmura's Avatar
dkmura
General & DIY Moderator
I listened to the entire vid, but it sure sounds like a squeaky belt to me. Why are you so certain it's not the accessory belt?
Old Feb 22, 2016 | 01:50 PM
HRMoneyPit's Avatar
HRMoneyPit
Sounds like a belt cause you pushing the pedal doesn't quite it
Old Feb 22, 2016 | 03:19 PM
Spike100's Avatar
Spike100
I had a very similar sound from my 350z. Initially I also thought it was a TOB. It wasn't a TOB; it was a belt.
Disclaimer: My sound only happened in very cold weather (which you do not experience in SoCal) so my advice might not be helpful.
Old Feb 24, 2016 | 07:44 PM
guitman32's Avatar
guitman32
Get someone to start it for you and try and isolate the location of the sound.
Pretty easy to find out if it is coming from the front of the engine or under the car from the trans.
Old Feb 25, 2016 | 03:10 PM
KJFire4Life's Avatar
KJFire4Life
wait for the noise to happen. Go under hood and spray brake clean on the belt. Noise goes away. theres your issue, otherwise do what guitman32 said above with a buddy!
Old Mar 1, 2016 | 11:16 AM
dkmura's Avatar
dkmura
Any updates on what this problem turned out to be?
Greg@TheZStore
Jun 24, 2016 05:31 PM
dragoonkane
Mar 3, 2016 08:18 PM
Reckless350z93
Feb 22, 2016 11:24 AM
J_Nunez33
Feb 19, 2016 01:17 PM
jdm-v35
Tuning
Feb 17, 2016 05:43 AM
