03 350z oil consumption HELP!!!
Old Feb 19, 2016 | 04:56 PM
ryanjarosz63's Avatar
ryanjarosz63
Default 03 350z oil consumption HELP!!!
alright so hear i go, i have a 2003 350z touring just hit 56k miles. i bought the car with 32k mile and had no issues til about the last thousand miles. i have been burning threw oil like crazy the pass two week its not funny.i know its "normal " for these engines to burn a decent amount of oil but this is just to much i feel like. i put 5 quarts this week about a quart a day.oil pressure reads normal and no light on. i check the drain plug today seemed fine check everything clean everything off and and i am ganna top it off once i leave work. and going to change oil tomorrow morning but i have 60 mile drive home tonight. i just hope nothing happens on my way home. if anyone has any feedback please reply
Old Feb 19, 2016 | 07:58 PM
dkmura's Avatar
dkmura
General & DIY Moderator
There's something quite wrong here. A VQ doesn't start burning oil that quickly unless its very sick. At the rate you're burning oil, is there a chance there's a hole in the oil sump? Or, are you leaving huge clouds of blue smoke wherever you go?
Old Feb 20, 2016 | 02:15 AM
350Z.'s Avatar
350Z.
well oil burn issue usually happen after your Z has 70,000 -100,000 miles and above . your car is low milage and it deserve to stop by Nissan Dealership.
I have 06 with 116k
Old Feb 21, 2016 | 11:41 AM
RWDBajan's Avatar
RWDBajan
5 quarts is basically the sump capacity. You'd have had to be dry to put that in. You must be leaving pools of oil wherever you go. Take it to the dealer asap unless you have 5k for an engine swap.
Old Feb 22, 2016 | 08:24 AM
CK_32's Avatar
CK_32
For starters is it LEAKING oil, or BURNING it?
Burning will have lots of white smoke out the back and you will smell it. If it's leaking it you need to find the leak. Id bet on fat leak over it burn that amount.
Old Feb 22, 2016 | 01:49 PM
dkmura's Avatar
dkmura
White smoke is typically water or antifreeze burning in the cylinders. Blue or black smoke is oil burning, but with the amount the OP is losing, there's little doubt he has a hole somewhere. All it takes is to jack up the car, support it on jack stands, grab a flashlight and trace the trail of oil. Wonder if he'll ever come back and update this thread?
Old Feb 22, 2016 | 03:52 PM
CK_32's Avatar
CK_32
Oh yea that's right.
All I remeber is my buddies SRT neon was burning and it was like a train of black/grey smoke. Smelt like crap too lol
Old Feb 22, 2016 | 04:09 PM
travlee's Avatar
travlee
Master
heaven forbid he takes it to nissan for a proper diagnosis
'03 350
May 13, 2024 01:54 PM
RallyZ
Feb 3, 2017 02:09 AM
tclark90
Nov 7, 2016 06:55 PM
Migz84
Feb 24, 2016 03:31 PM
Homam
Feb 23, 2016 04:59 PM
