2006 350Z Raodster Convertible Issue
Old Mar 30, 2016 | 05:03 PM
GymRat11's Avatar
GymRat11
Unhappy 2006 350Z Raodster Convertible Issue
I purchased a 2006 350Z Roadster last week from a dealer in Georgia. When it arrived in Pennsylvania the convertible didn't work. I know that it worked prior to transport because I saw pics of it with the top down. There is no power at all. I talked to a Nissan Tech and then on his advice checked the 3 fuses in the interior fuse box...they are all good. then checked to make sure there's power to the fusebox and all fuses. Again all good. There's no sound and nothing happens at all when pressing the open button. The Tech also had me disconnect the negative cable from the battery and let sit for 15 minutes to reset the car, I'm assuming the ECU. That did nothing also. Any idea what the problem is? Could it be as simple as the open/close switch being bad?
Last edited by GymRat11; Mar 30, 2016 at 05:08 PM. Reason: Needed to add other things I've tried to fix problem.
Old Mar 31, 2016 | 02:47 PM
jogquinteros's Avatar
jogquinteros
Ok this may sound like a dumb idea, and you may already know this, but are you pressing the "brake pedal"? You must press the "brake pedal to open or close the top. I personally forgot about it in the following days. Not trying to insult your intelligence.
Old Mar 31, 2016 | 09:52 PM
GymRat11's Avatar
GymRat11
Not insulted, I found that out the day after I posted! The top works fine. I just bought the car a week ago and it didn't have the owners manual. I ordered one and it'll be here Saturday. Thanks for answering me.
Matt Underwood
Mar 24, 2016 07:27 PM
Stephen_Neri
Mar 23, 2016 09:33 AM
Branden Nguyen
350Z Roadster
Mar 8, 2016 12:38 PM
bocbos
Mar 4, 2016 09:35 AM
