p300 Code
Old Sep 14, 2016 | 06:28 PM
bagpiper's Avatar
bagpiper
Default p300 Code
I just want to throw this out there for other that may get the p300 multi cylinder misfire.
Mine ended up being a failing ignition coil pack. When I say failing, from a cold startup, I noticed the engine would run smooth for about 15-20 seconds then sputter. After 15-20 seconds the coil electronics start heating up and fail.
To get to my solution, I changed plugs which were needed anyway and tested each coil pack for resistance as suggested in another post. All the coil packs test ok for resistance. I then followed the method of disconnecting each coil pack to observe engine drop off. When I found the faulty pack I marked it and moved it to a different cylinder. In my case #5 was bad and I moved it to #1 and tested the engine drop again to confirm it was that coil pack I moved to #1. I replaced the coil pack and runs great again. Coil pack was ordered from rockauto ~$37 for a OEM Hitachi coil pack.
Hope this helps if you have the same symptoms. P300 can be a pain in the a$$.
2004z 130k miles and a modified AEM intake, got it used.
Old Sep 15, 2016 | 01:06 AM
ATIX's Avatar
ATIX
Great! thanks for that info! I'm having the same error code but I think my problem is different.
My car runs fine until I start accelerating I lose power and all the spark plugs smell like gas.
Thank you nevertheless!
mbissani
Sep 17, 2016 06:49 PM
shortyhoward
Sep 14, 2016 11:14 AM
Edneil Sundar
Sep 11, 2016 12:52 PM
Dloyd350
Sep 11, 2016 12:29 AM
