Floor jack point for front end
Old Apr 6, 2017 | 03:12 PM
Odunn's Avatar
Odunn
Default Floor jack point for front end
The spot marked yellow a good/safe spot? You have to click it and soon I'm. I'm trying to get to o2 sensor upstream on the passenger side. Man its like wrestling a bear. I even got a special socket and breaker bar.
Old Apr 6, 2017 | 03:45 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Single jack points F&R: Under the diff for rear, center of K-member front. I think that's what's on your pic so yes, that's correct.
Old Apr 6, 2017 | 04:03 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Call me nervous about this practice, but "wrestling bears" and single jack points, just don't mix. If anything is unsteady, I want two/four jack stands in the designated spots on both sides of the chassis before I apply any type of breaker bar.
Old Apr 6, 2017 | 04:07 PM
Odunn's Avatar
Odunn
Ya I'm extremely paranoid but I have the Jack stands and chok block and I leave the jack in place eased off just in case.
Old Apr 6, 2017 | 05:50 PM
MicVelo's Avatar
You know what they say about "assume", David.
I made that jackstand assumption here. Bad me!!
Old Apr 6, 2017 | 09:14 PM
CK_32's Avatar
CK_32
Yea don't lift by your oil pan...
I just noticed on my Z even after I told my buddy do not lift it from my oil pan he jacked the car up by the oil pan... It's now dented and concaved.
Hopefully I can hammer this sht back out and not have to go buy a whole new god dam pan....
I was wondering how he got it jacked up so fast while I was getting to tools from my garage
Old Apr 7, 2017 | 05:58 AM
Odunn's Avatar
Odunn
No not the pan, that little black area where the rods or whatever come together between the wheels, circles in yellow. Although I have a low profile jack I put one jack stand on the side front so I can get to the marked spot.
Old Apr 7, 2017 | 08:47 AM
rancor's Avatar
rancor
The two post lift points on that car are not in the correct place the yellow area you have circled are the correct front and rear jack points.
Old Apr 7, 2017 | 02:59 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
I use the front engine cradle... Have jack stands under the tow loops, and put wooden supports under the tires...
Also throw an extra wheel with tire under their with me as a last line of defense.
Havent died from crushing yet..
Those maifold 02 sensors suck my ***... I used an 02 stubby with a 8 inch extension an adapter and the breaker bar...
Good luck getting it unclipped. Thats also a *****.
