2004 350z won't start
Old May 30, 2017 | 01:12 AM
Wsheff's Avatar
Wsheff
Default 2004 350z won't start
So my 350z hasn't been running for almost a year now and still no idea on why it won't start. I hooked it up to an OBDII scanner 2 weeks ago and it threw both cam shaft sensor codes and I replaced them both and still won't start. Idk if it's been sitting too long or what. When it started to go out it was losing power would stall and all that good stuff like a cam shaft sensor going out but at the time it was breaking down I didn't know what I was doing and let it sit for a year until I researched about the car and started working on it. The battery is also pretty dead so everytime I try to start it I have too get a jump so idk if it's because I'm not getting full power from the battery.
Old May 30, 2017 | 01:17 AM
Wsheff's Avatar
Wsheff
Any tips or things that may help please throw them my way.
Old May 30, 2017 | 01:24 AM
Wsheff's Avatar
Wsheff
Also when I try starting her it sounds like it wants to fire up but won't.
Old May 30, 2017 | 05:53 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Hey, Wsheff.
Has it been sitting outside, or inside for a year?...
- Regardless, I would do a compression/leak down test first to determine the health of the engine above the crank.
- If the results are within specs, I would then change the oil and check the condition of your spark plugs(if they are wet or heavy with carbon deposits, replace).
- Did you get OEM Nissan camshaft sensors? (These cars DO NOT like generic sensors)
- Check your air filter for critters, extensive clogging.
- Replace battery or have yours charged(if it will still hold a charge).
Old May 30, 2017 | 06:05 AM
jhc's Avatar
jhc
General & Tech Moderator
Another consideration in the age of Ethanol blended fuels- siphon all the gas and start with fresh 93. I've heard it doesn't do well sitting for long periods. Good luck!
Old May 30, 2017 | 02:18 PM
Wsheff's Avatar
Wsheff
Originally Posted by Atreyu'z 350
Hey, Wsheff.
It has been sitting outside.
And no I didn't use the OEM sensors but it isn't throwing the codes anymore.
Old May 31, 2017 | 05:57 AM
travlee's Avatar
travlee
Master
many many threads about crap non oem sensors causing problems
Old May 31, 2017 | 09:28 AM
Atreyu'z 350
Not good. I would still do a compression test, and if the results come back good, then you're on solid ground. You don't want to throw money at a dead engine.
Old May 31, 2017 | 09:30 AM
Atreyu'z 350
He's in Texas, Trav. Go fix his car.
Old May 31, 2017 | 09:45 AM
travlee's Avatar
travlee
Master
texas is a huge state, i mean you can drive 9 hours and still be in it..... plus he cant afford me
Old May 31, 2017 | 10:01 AM
Atreyu'z 350
Old Jun 4, 2017 | 11:33 PM
Wsheff's Avatar
Wsheff
what should the compression be around?
Old Jun 5, 2017 | 02:50 AM
travlee's Avatar
travlee
Master
guess google is not your strong point
Old Jun 5, 2017 | 07:03 AM
Atreyu'z 350
On a new motor the numbers are between 185 - 190psi. across all cylinders. The minimum tolerance is 142psi. You'll probably be anywhere between 155 - 178psi. across all cylinders, which is OK.
Old Jun 5, 2017 | 07:18 AM
Atreyu'z 350
