Clutch going out?? Help!
Old Jun 14, 2017 | 03:45 PM
D'sNAz's Avatar
D'sNAz
Exclamation Clutch going out?? Help!
Recently replaced my motor. Been driving the z for two days and she's been a beauty. Today, I was driving home and in first gear and right as I hit 5k my RPMs started jumping like crazy so I let go of the gas. Took off again and it kept doing it. I've never experienced this problem till now. What could it be? Clutch going out? ECU in limp mode? Also as I'm driving as I'm shifting my gears start grinding all throughout. I have to let the clutch pressed I. As I put it in neutral then back into the next gear and everything goes smoothly. Any input would be great. Thank you guys
Old Jun 14, 2017 | 04:02 PM
zakmartin's Avatar
zakmartin
Who installed the new engine?
Old Jun 14, 2017 | 05:54 PM
D'sNAz's Avatar
D'sNAz
Me and my mechanic friend. He works for dealerships. And this is my second swap I've done. Any insiders tho. Don't hold back, y'all won't hurt my feelings.
Old Jun 15, 2017 | 07:52 AM
dcains's Avatar
dcains
Do you mean when you were in 5th gear and you stepped on the throttle, the revs went up the car's speed didn't? If yes, that's a slipping clutch, and it may or may not do it in lower gears, but it will eventually if you don't fix it.
Old Jun 15, 2017 | 12:06 PM
D'sNAz's Avatar
D'sNAz
It jumps with all the gears and it sounds like it's grinding on all gears too. I had someone tell me the pilot bearing. Since I took an automatic engine and put it into my manual transmission. Is this correct?
Old Jun 15, 2017 | 01:21 PM
dcains's Avatar
dcains
if you're saying there's no pilot bushing, then yes, that's one problem, and you need to install one. Would a missing pilot bushing cause your symptoms? I don't know.
Old Jun 15, 2017 | 03:24 PM
D'sNAz's Avatar
D'sNAz
I have a video on what it does. I just ordered a pilot bushing from z1 so I'll just wait for it.
Old Jun 15, 2017 | 05:24 PM
guitman32's Avatar
guitman32
Sounds like a failing master/slave cylinder, which may or may not have lead to a failing clutch.
If you are running the car with no pilot bushing, your input shaft is basically completely unsupported on one end.
Keep in mind auto and manual 350zs have different pilot bushings. To do what you are doing you need an adapter if memory serves.
Old Jun 16, 2017 | 04:13 AM
D'sNAz's Avatar
D'sNAz
I'll check everything once I get the new pilot bearing. What would cause my RPMs to jump all crazy tho?
Old Jun 16, 2017 | 08:45 AM
iideadeyeii's Avatar
iideadeyeii
Clutch slipping would only do that.
Did the tranny mate fine to the engine?
As for the grinding it sounds like the clutch isn't disengaging completely
Old Jun 16, 2017 | 09:38 AM
Extreme Dimensions's Avatar
Extreme Dimensions
Vendor - Former Vendor
Did you replace the clutch when doing the engine? New parts wear out older parts quickly.
Old Jun 16, 2017 | 11:31 PM
D'sNAz's Avatar
D'sNAz
I did not replace the clutch. The clutch is a year old. And yes, the transmission bolted onto the engine just fine. It worked great for two days before it started doing this. I went to work and after I get off it started doing. So I was a little lost on why.
