Please Help ! Need new clutch kit and Flywheel
Old Nov 2, 2017 | 01:58 PM
Jonathan Umana's Avatar
Jonathan Umana
Default Please Help ! Need new clutch kit and Flywheel
I went to nissan dealership who informed that I was in need of a new clutch and flywheel and apparently since I have a 2008 it has dual flywheels making the price go upwards of 4,000 dollars for an OEM Clutch , anyone have better recommendation for less money ?? Please and Thank you to anyone
Old Nov 2, 2017 | 02:21 PM
travlee's Avatar
travlee
Master
Can you do labor yourself? If so jwt combo, but while you have trans out, replace the crap csc with the zspeed hd one. You are still looking at 1500 ish doing it yourself
Old Nov 2, 2017 | 04:05 PM
bealljk's Avatar
bealljk
$15 for DIY?
I think I paid $1300 for the parts & labor back in the day for the JWT combo...
Old Nov 2, 2017 | 04:26 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Just FYI, it's not actually dual flywheels... it's called a "dual mass flywheel" where there are offsetting "counterweights" inside (usually springs acting like counterweights on a planetary DMF like the Z's). But it's a single unit, not two. And it's not unique to your '08. All Z33s (and Z34s) are equipped as such from 2002-on to today.
I second the nomination for the JWT kit but be aware that they're sold in two differing versions: One with a lightened flywheel for easy engine revs and the other with a heavier iron flywheel (but still a bit lighter than the OE DMF). Which to choose depends on what you use the car for.
If it's a track beast (or dual purpose), the lighter unit does free up the engine and getting into the power band is faster. OTOH, if your car is primarily a street/DD car, I would "suggest" the iron unit so that there's inertia behind the engine making for smoother driving on streets and freeways. I've run both on varying cars and there are advantages and pitfalls to both so study up on it and be honest with yourself about how the car is used.
Old Nov 2, 2017 | 08:33 PM
bealljk's Avatar
bealljk
I went with the lighter of the two and it was a definitely a difference ... I stalled the car out quite a bit the first days and it'll require you to relearn how you let the clutch out and hit the gas.
Old Nov 2, 2017 | 10:56 PM
Jonathan Umana
Default Thanks !
Thanks for informing I thought it sounded weird that it was a dual flywheel but I just assumed he was in the right , thanks Ima look into the JWT combo
Jonathan Umana
Default Thanks
Ima going to look into it right now and see how it is
Old Nov 2, 2017 | 10:58 PM
Jonathan Umana
Default Thanks !
My friend works for nissan and can replace it for me just have to buy the parts I just wasnt sure what parts to acquire , he told me the OEM parts were the best since I havent upgraded the horsepower yet
Old Nov 3, 2017 | 01:12 AM
MicVelo's Avatar
There is no doubt that the Nissan OEM parts are good; but that $4k price tag isn't so good. The prices that the guys have suggested are right on the money (no pun intended).
Oh, and not to diss the Nissan parts guy (I used to be one long ago!) but for him to tell you there are two flywheels.... uhh, well, there's his cred out the window.
Also pay big heed to Travlee's advice (above) regarding the concentric slave cylinder. Don't use OEM for that, it's not a good option because it's possible it will still fail in less time than it should.
Good luck!
Old Nov 3, 2017 | 03:57 AM
travlee's Avatar
travlee
Master
$15 for DIY?
i was figuring, clutch/flywheel ($549), zspeed hd csc, and new master ($525)..and room if he needs anything else, if he couldnt do the labor then about another $500 if not more
Old Nov 3, 2017 | 03:59 AM
travlee's Avatar
travlee
Master
Good luck!
true story, mine went out 3 months after i got the car from dealership.... i went back and bitched at them and they said since i paid cash for the car they would do the work for cost... well fast forward a year and it went out again.
Old Nov 3, 2017 | 11:13 AM
deeliciousqueen's Avatar
deeliciousqueen
Default All you need
Under $900 parts and about $400-500 labor. Ask your friend if he's ok to do the labor for $300 and some 12pack lol. Of course he would recommend oem nissan parts since he works for nissan but IMO, aftermarket parts are as reliable as well as long as you did your research on them. The links below are all you need to get that clutch biting hard again.
Just be aware of the chatter that comes with aluminum flywheels, they will sound like UPS trucks but you will get used to it and nothing wrong with that, the pros will outweigh the cons and you can feel it when you are driving. GL
https://conceptzperformance.com/jim-...ktb_p_2423.php
https://conceptzperformance.com/wilw...87_p_29105.php
http://www.zspeedperformance.com/ZSp...P-CMAK-SSC.htm
https://conceptzperformance.com/motu...rsal_p_251.php
Old Nov 3, 2017 | 04:54 PM
Jonathan Umana
Default Thanks man
Your the man, I was looking at this clutch kit and seeing all those extra parts to help it fit better and properly I really appreciate it
Old Nov 24, 2017 | 01:10 PM
Jonathan Umana
Thanks Guys got the parts installed except for Master cylinder and Clutch slave cylinder they didnt fit
Old Nov 24, 2017 | 01:51 PM
bealljk's Avatar
bealljk
parts installed
what setup did you end up going with? thoughts versus your previous setup?
