Idle drop at warm startup
Old Nov 13, 2017 | 07:35 AM
lazer450's Avatar
lazer450
Default Idle drop at warm startup
08' 350z
Hello,
I'm having an issue identical to this post: https://my350z.com/forum/maintenance-and-repair/598925-car-stalling-at-warm-startup.html. It has been doing this since for a long time without any codes. Did an idle air relearn, and got the MAF cleaned. Any help would be greatly appreciated.
Old Nov 13, 2017 | 08:11 AM
travlee's Avatar
travlee
Master
does it die and then take a minute to start back up? if so, my guess is camshaft position sensors
Old Nov 13, 2017 | 01:36 PM
lazer450's Avatar
lazer450
Thanks for responding so quickly. It only dies every once in a while. When it dies, i have to give it a little gas the second time and it doesn't die. 98% of the time, it drops and levels out identical to that video. What ended up being the problem with your Z?
Old Nov 13, 2017 | 02:21 PM
travlee's Avatar
travlee
Master
I personally never had the issue, but seen many that have
Old Nov 13, 2017 | 04:26 PM
Atreyu'z 350's Avatar
Atreyu'z 350
OP, did you touch/move the butterfly valve in your throttle body?
Old Nov 14, 2017 | 05:14 PM
lazer450's Avatar
lazer450
I haven't tampered with the throttle body. I was going to clean it, but the dealership recommended against it. They said it could cause more problems. You think the valve is stuck? Or is that common with Z's? The car has 86,000 on it.
p.s I'm not a car guy, so I apologize for my ignorance lol. Thank you guys for your input.
Old Nov 15, 2017 | 04:13 AM
Atreyu'z 350
OK.. No, I don't think it's stuck. Just that the servo motor that controls the valve is electronically driven, so opening and closing the valve manually will sometimes cause it to loose its zero-point. And the dealership is right. It is best cleaned while it's running.
Old Nov 15, 2017 | 04:20 AM
travlee's Avatar
travlee
Master
i would try the idle air relearn, throttle position relearn, etc etc
Old Nov 16, 2017 | 06:05 PM
lazer450's Avatar
lazer450
Thanks guys. I'll run it through the relearn processes, and let you know how it pans out. If it is still having issues, I'm sure you'll have some other recommendations for me.
Thanks again for the help!
Old Jul 26, 2018 | 03:09 PM
PD27's Avatar
PD27
Clean your throttle heads, don't listen to the stealership, they want you to pay more to have their service departments do the same thing and fleece you in the mean time. It's really pretty easy and there's a ton of videos on Youtube.
Old Jul 26, 2018 | 03:56 PM
travlee's Avatar
travlee
Master
8 months late to the party
Old Oct 16, 2018 | 11:08 PM
NarcisoG.'s Avatar
NarcisoG.
Default I’m having the same problems
My 05 350z will start from a cold start and stay running until the car warms up and the RPM drops to where it’s supposed to be when warm. Then it will run for a few seconds and stall. The car will start again right away and run for about 10 to 15 seconds then it’ll stall again. Now it’ll do this over and over again until I turn the AC on, Then The car will stay on but it doesn’t idle as smooth as it used to. As soon as the AC is shut off the car stalls. I have no check engine light on and no codes come up on the scan tool. The fuel pump is brand new so is the MAF sensor, and all o2 sensors. I’ve had a few people tell me it’s the cam posistion sensors or the crank sensor. Then I hand another guy say it could be fuel pressure isn’t enough or the ecu is having issues. I did clean the throttle body and i did it very carefully and I did the throttle relean for and everything worked fine there was no problems then. Any ideas what it could be?
findre
May 7, 2026 10:10 AM
Feffman
Dec 27, 2017 04:18 AM
Feffman
Oct 24, 2017 06:10 PM
ARG350Z
Oct 5, 2017 10:33 AM
