Part number and DIY for rear hatch window rubber seal?
Old Jan 27, 2018 | 01:40 PM
phreaktor's Avatar
phreaktor
Design Engineer
Default Part number and DIY for rear hatch window rubber seal?
Quick question- What is the part number for the outer hard rubber seal that goes around the sides and bottom of the back glass? I found a part number but it appears to be for the inside of the hatch as it comes in a roll and the part I need is formed to the shape of the glass.. Also, what is the proper method for installing this seal? Does the whole rear glass panel need to be removed and reinstalled with new adhesive or can the rubber seal be installed without removing the glass? Is this something best left to pros at a glass shop? Any special tools required? Your help is appreciated.
Torrey
Old Jan 29, 2018 | 09:42 AM
zakmartin's Avatar
zakmartin
It's in the FSM under GW. Go to page 14 for the procedure on the 2007 model. The part is called the "back door window molding."
http://www.nicoclub.com/manuals/350Z/coupe/2007/gw.pdf
Personally, I'd take it to a glass shop to get it done. Windows that big are a bear to work on and a decent glass shop will be set up to do it fast and get the right amount of adhesive on it so it doesn't look like garbage. Since you're going to re-use the window, which is the bulk of the cost, you're just going to pay for the molding and the 1/2 hour or so of labor it'll take for them to swap the part out.
Old Jan 30, 2018 | 08:51 AM
phreaktor's Avatar
phreaktor
Design Engineer
Thank you. The thing is only the "Back door window molding" rubber strip needs to be reinstalled. The whole window doesn't need to be cut out and replaced with new adhesive. I may be able to do it myself. I can't get the old molding to fit back into place because it is hard and warped. Found the part (90352-CD000): https://www.ebay.com/itm/NISSAN-9035...hZygNz&vxp=mtr
BIGPOPPAPUMP
Jul 1, 2014 06:49 PM
jeffnot
Mar 19, 2013 09:23 PM
marthur544
Apr 28, 2006 08:07 PM
bobbyz
Feb 12, 2004 06:37 AM
