Help! Dash lights are on: ABS, TCS, etc.
ABS, TCS, etc. are lit on the dash cluster of my '04 Z...
I was told that it could be a faulty ABS pump.
Did some research online & seen that most said that its the camshaft sensor.
Anyone has a remedy to this problem?
Good guess, as that's most likely what it is. Is your check engine light also on?
First of all I’m dealing with that as of right now exact issue, not sure why’d my issue would be similar but through my time and energy I’m sure we have the exact same problem. Hopefully I’d you resolve it, without having to waste time with the wrong source hope we can do this together
If either the OP or limp350Z would take the time to download codes from the ECM or ABS diagnostic systems, they'd have a fighting chance to figure out what's gone wrong with their Z.
