Squeaking/grinding noise...help!
Old Jun 29, 2018 | 11:13 PM
Trevor Corey's Avatar
Trevor Corey
Exclamation Squeaking/grinding noise...help!
I've had this noise coming from my rear end(?) for about three weeks now, it started out as a slight squeak with each revolution and is now a very loud squeak and almost like a grinding when I am coming to a stop. There also seems to be a sort of pop when I first get the car moving in gear (first, second, and reverse) that I do not know if it is related. At first I thought it may be a brake problem as the sound started shortly after I got my brakes done, however I noticed in the video below that the squeaking sometimes goes away when I press the clutch in (you can hear when this is done and the last example in the video I do a cringy countdown for it). As if the noise wasn't enough, I also hit a deer and destroyed my front bumper, fender, and put a giant dent in my door. I have had a hell of a month and would love some help diagnosing this problem before taking it to any shops. Thanks a lot!
Old Jun 30, 2018 | 04:57 PM
guitman32's Avatar
guitman32
Very hard to hear, could be many things. You need to get the rear end up and inspect, or get a friend to walk by the car as you drive slowly.
Welcome, let us know what you find.
Old Jul 2, 2018 | 08:02 AM
SpartaEvolution's Avatar
SpartaEvolution
Does lightly pulling the ebrake while you're moving make any difference? Those drum mechanisms are prone to sticking, and it that would explain why it feels 'stuck' when you get going.
Old Jul 2, 2018 | 09:00 AM
travlee's Avatar
travlee
Master
dang sparta... no corvette love in your line up.
op the pop is prob the very common rear axle pop... just needs re greasing
Old Jul 2, 2018 | 10:02 AM
SpartaEvolution
Called out! Sorry Trav, we figured anybody looking to improve braking performance on a vette just bolts a parachute to the back :P
jdm-v35
Sep 18, 2009 12:17 PM
scoobydude
Jun 3, 2008 05:24 PM
valdeztke
Mar 24, 2005 12:17 PM
ROME
Oct 16, 2004 11:27 PM
03daytonablue
Feb 6, 2004 05:22 PM
