Need proper P/N fir HID igniter
Old Oct 29, 2018 | 05:17 PM
TangoAlphaZulu's Avatar
TangoAlphaZulu
Default Need proper P/N fir HID igniter
Good evening all. I need some help getting a part number for the HID headlight igniter on the g/f's 2004 350z. Below is a picture of the part that came off of the car.
Looking at AutoZone and O,Reilly, they say P/N 601-166, pictured below, is the correct part for the car. Alas, the strain relief / ground tab is not in the right spot, and there is no spade connector on the light head for the small ground strap from the housing.
Does anyone have a part number that will get me the part at the top?
Thanks,
Jeff
Old Oct 29, 2018 | 07:25 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Take the VIN to a Nissan parts department and they'll get you to correct part #.
Old Oct 30, 2018 | 04:31 AM
travlee's Avatar
travlee
Master
courtesyparts.com
Old Oct 30, 2018 | 05:36 AM
Freise's Avatar
Freise
I'm not sure if the grounds will be any different or not, but most/all nissans from the 2000's with standard HID's, even common ones like altimas and maximas used the same ballast and I think igniter. If you have access to a salvage yard it might be worth checking out.
Heel Til I Die's Avatar
Heel Til I Die
I'm no help with the part number, but it's called a Matsushita Gen 3 igniter. If you search that, you can find them for about $15 on fleabay.
XERMAN2001
Apr 22, 2010 07:00 PM
sxr891
Oct 18, 2009 05:55 AM
RANDY350Z
Jun 24, 2007 08:27 PM
